Slack Trigger Node Webhook URL: per credential, not per node
I want to listen for slack events in multiple different workflows, however, when I create multiple “Slack Trigger Nodes” each one has a unique webhook url.
The challenge is this: the each slack credential is associated with an individual slack app. each slack app is allowed to have a single event webhook endpoint.
That means that in order to use the slack event trigger, I have to have a single workflow with a single “slack trigger node” that then in turn calls out to every other workflow I want to use the slack events in. It sort of has to be the “every event” node for this to work, and then I have to filter elsewhere.
I would love it if the webhook was specific to the slack credential used, OR if I can specify the webhook url, so multiple triggers could use the same url.
Thanks!
  • 1.81.4
  • Postgres
  • Own
  • Docker
  • Ubuntu 24.04.2 LTS
Honestly a “router” workflow seems like a solid solution, handle all logic of what goes where, there.
Duplicating slack triggers sounds like a nightmare and could cause weird problems if routing the same trigger to multiple scenarios.
