Hey there, I’m Felix, and I ran into a problem that seems to affect multiple n8n users. I’m not very technical, and I wanted to set up a workflow to extract data from invoices easily so I wouldn’t have to do it manually anymore.
At first, I tried using the n8n extractor, but unfortunately, every time I uploaded a PDF, the workflow would stop working because of an error. After several attempts to fix the issue, I realized that an external solution integrated via API might be the way to solve my problem.
I looked into several options (Unstract, LlamaParse, and even some smaller solutions), but they all required a pretty heavy setup before I could integrate them and run a workflow.
Since I have some friends who work as developers, I asked them for help. Of course, they eventually fixed my n8n workflow, but it felt strange. n8n is supposed to be accessible for people like me, yet I still needed my tech friends to get it running.
That’s when we decided to create the simplest data extraction tool possible: no coding, no complex setup, just simple field mapping. My friends suggested a schema-driven approach so the output would be structured and easy to integrate into other software later.
I can honestly recommend anyone give it a try. It’s really straightforward and can be implemented easily via an HTTP Node in n8n. You can even check out a workflow I built with it here:
https://n8n.io/workflows/11659-automated-expense-tracking-with-telegram-easybits-and-google-sheets/
You can test the tool here:
https://extractor.easybits.tech/
I also created an onboarding video to make it easier for people in my network who are working with automation:
https://www.loom.com/share/c28995efca814a809acbcefd5a0303cf
I’d be really happy to gather some feedback, and if you have any questions, please feel free to leave a comment.
