I am having problems connecting to Google AI Studio via n8n. I encounter a variety of different issues depending on how I attempt to access it. I host n8n on a Hetzner server, located in Germany. I am also physically located in Germany.
I have no issues connecting to and accessing Google AI Studio (specifically, Gemini Flash) directly. I have a curl command that I run locally with my API key, and it functions correctly.
However, if I use an HTTP node in n8n and select ‘import from curl’, I get the following error:
User location is not supported for the API use.
Error details
From HTTP Request
Error code
400
Full message
400 - "{\n \"error\": {\n \"code\": 400,\n \"message\": \"User location is not supported for the API use.\",\n \"status\": \"FAILED_PRECONDITION\"\n }\n}\n"
Request
{ "body": { "contents": [ { "parts": [ { "text": "Explain how AI works" } ] } ] }, "headers": { "accept": "application/json,text/html,application/xhtml+xml,application/xml,text/*;q=0.9, image/*;q=0.8, */*;q=0.7" }, "method": "POST", "uri": "https://generativelanguage.googleapis.com/v1beta/models/gemini-1.5-flash:generateContent", "gzip": true, "rejectUnauthorized": true, "followRedirect": true, "resolveWithFullResponse": true, "followAllRedirects": true, "timeout": 300000, "qs": { "key": "AIzaSyAKhDtp5285bVprtjqGwr0G9dFBx9108Ps" }, "encoding": null, "json": false, "useStream": true }
Other info
Item Index
0
Node type
n8n-nodes-base.httpRequest
Node version
4.2 (Latest)
n8n version
1.75.2 (Self Hosted)
Time
27/01/2025, 12:18:30
Stack trace
NodeApiError: Bad request - please check your parameters at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/HttpRequest/V3/HttpRequestV3.node.js:525:33) at processTicksAndRejections (node:internal/process/task_queues:95:5) at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:632:19) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:890:51 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1224:20`Preformatted text`
type or paste code here
This is very weird… ‘User location is not supported for the API use.’ I am not using a location parameter, and I am located in Germany. Moreover, the server is also hosted in Germany. I have verified that Germany is a supported location.
I previously encountered some other issues that I can no longer reproduce. I was told that my API key was not working, but the project ID in the error message did not match the project associated with the API key, nor any of my project IDs in general. I revoked the API keys and changed some other things; now I am not getting that error anymore.
I would really appreciate some help, or a direction, that I can focus my efforts on. Thanks.
