The idea is:
Switch node attachment points should be connected to specific output, currently they are connected to n’th output and move around when new outputs are added or removed.
My use case:
I expect my output nodes to be attached to outputs I’ve attached them too.
Currently, if I have 2 outputs and “fallback” and add 3rd one things will move around and my fallback node will attach itself to 3rd output.
Currently changes to the node require double checking connections, this increases change of mistakes if a lot of nodes are present.
No
No
