Telegram buttons and the wait for webhook node questions
I am sending a message to a telegram bot, and then using the wait for webhook node to wait for the reply before continuing. That works fine if I just use text links in the message I am sending telegram from n8n and insert the wait node webhook.
eg: Please tap [Go]({{ $execution.resumeUrl }}?answer=go) or [No]({{ $execution.resumeUrl }}?answer=no).
But
I want to make this work with buttons so I have added in an additional telegram node to send buttons that would replace the text tap option. I have added [Go]({{ $execution.resumeUrl }}?answer=go) to the call back data field but it seems either
  • the webhook is not being generated on execution
  • telegram is not sending the webhook back when the button is tapped
  • the webhook is not being recognised by the wait node
Because the wait node just waits for ever.
The work flow shared here is a part of a bigger workflow where a telegram chat is initiated and a chat ID created and then used in this action telegram nodes
Any one have any idea how to get this working?
you want to use a telegram trigger no?
CleanShot 2024-06-28 at 15.00.03@2x
Not in this use case. I am sending information to telegram for a customer to make as approved or not approved.
I want to use buttons for that function and tie that in with the wait for webhook feature of n8n’s wait node
I have got it working with Telegram1 node but not with the buttons. Had a quick search and found the below thread which goes into more detail with using the buttons
have a look here and modify for your use
Thanks,
I did go through that thread and the workflows in the detail before posting as I could not get it to work.
I think I am making a mistake in configuring the telegram node that is using providing the telegram buttons as I can’t get the buttons to active the n8n {{ $execution.resumeUrl }} webhook like I can when sending clickable text.
Is the issue not with the Go and No before the URL? I would have thought those would make the URL invalid.
I have tested with various iterations, and every time the wait node just keeps waiting.
Here is a test work flow and a loom video showing the action
The loading doesn’t seem to suggest it has finished loading, Does Telegram expect a specifc response back?
No idea,
If you look at the 1st telegram node in my original post, I am using the resume-url with text rather than buttons and that works perfectly.
I think the loading I am seeing in Telegram is telegram trying to load the webhook url as when I use the text based option it actually loads a web page with a success message.
Maybe the webhook url is not being loaded? Not sure how to investigate.
Hey @Robm,
You could try using something like webhook.site for the urls and see if you get the request to the URL it gives you that could be a good starting point.
At some point today I do want to test this though.
Aa the resume_urls are generated dymanically when the automations runs, how would I know what url to test with webhook.site?
Hi, Did you figure this out? I have the exact same issues, and can’t quite find way around it
