Telegram → Send and Wait for Response - Need full output - message.id
Hello n8n Team,
I’m loving the new Telegram → Send and Wait for Response node, but I ran into a scenario where I need to automatically delete the prompt message after the user clicks “Approve” or “Reject.” Currently, that node’s output only returns a minimal object:
“data”: {
“approved”: true
Because I don’t get back the full callback_query payload (in particular, the chat.id and message_id), I cannot call the Delete Message API to remove the button prompt. In practice this leads to confusion in my chat, because old approval messages stack up and I can’t clean them up.
What I’d like to see added:
  1. Full callback_query object in the node’s output (e.g. under .raw), so I can access:
  2. callback_query.message.chat.id
  3. callback_query.message.message_id
Either of these would allow flows that ask for confirmation to immediately clean up their own messages, keeping the chat tidy.
Thank you for considering this enhancement! Please let me know if you need any further details or examples of how I’m using the node.
Best regards,
I have the same need, did you find a solution ?
no :frowning: maybe devs will add it
my ticketing system is also need that feature so it can “reply to message id” which ticket has been approved or rejected.
dev team please add the callback_query output detail
Same issue. Devs please do something.
try to use the “I wish this node would…” at the bottom
I found a rather hacky approach.
I first send a normal message, then use the “wait for response” message.
I delete the normal message using its available message_id, and finally delete the “wait for response” message using {{ $(‘Send a text message’).item.json.result.message_id + 1 }}.
This works for me for now, but I’m not running this automation intensively.
