The idea is:
A toggle on every node for debugging/developing to run the current node with the last/current input data vs running all previous nodes
My use case:
I need to develop with code nodes calling services that have a usage limit/cost, so keeping the current workflow data for that node(or a possibility to save current workflow up to a certain point for reuse in development)
Yes
That was a useful hint @dickhoning ! Thank you for this.
I was dealing with such problems like this: run the workflow once. Toggle the input data to be shown as json. Copy that JSON. Create a Code node with that JSON as returned value eg. return [{key: 2, otherKey: "wohooo"}];. Connect this node to the one you develop/debug and save that workflow.
Hi @dkrueger you’re very welcome!
I’ve also got a lot of ‘dummy/mockup’ code nodes in my workflows, where I store json for further/onward testing.
Thinking about this, perhaps it would be nice to have a ‘Mockup’ or ‘JSON Data’ node, where you just copy in JSON for testing/developing. And even nicer if this node would have a build-in JSON Validator (such as https://jsonlint.com), and something like https://jsonpathfinder.com
I use these tools practically all the time when I’m developing workflows in n8n …
