Tool Agent: problems with http tool
Hello guys,
I have a problem. I am using a tools agent to fetch information about my company from different sources, but it always get an empty response. Checking through the logs, I noticed the search query contains spaces (despite instructions to URL-encode), and I though this breaks the query:
I tried to URL encode using {{ encodeURIComponent($json[“query”]) }} and {{ encodeURIComponent({query}) }}, but I can never get the actual query (keep in mind this is from the agent to the tool, so I cannot intercept the query to modify it).
Then checking more logs, I found some instances of queries that do not contain spaces, and still don’t get any result:
When I use the query in an incognito browser, I get results for that URL (https://community.gainium.io/search.json?q=category:bug-reports%20combo):
So while still useful to know how to get the URL encoding to work, that doesn’t seem to be the issue.
The only way I got this to work is by using a subworkflow tool instead of directly calling the HTTP, in the subworkflow I can use urlencode without issues and more flexibility. However that means creating a lot of other workflows and it’s a little bit messier.
Thank you for your help.
