Transcribing audio to script
Error is the attached image
  • n8n version: 1.99.1
Workflow is below:
“nodes”: [
“parameters”: {
“content”: “# :brown_square: STEP 1 — Clone a viral TikTok video”,
“height”: 300,
“width”: 2460
“id”: “a64b5155-4f15-40cc-9d83-1de8ef070bd9”,
“name”: “Sticky Note”,
“type”: “n8n-nodes-base.stickyNote”,
“position”: [
0,
0
“typeVersion”: 1
“parameters”: {
“updates”: [
“message”
“additionalFields”: {}
“id”: “48c60954-0307-40fa-872a-d524a189dd60”,
“name”: “Trigger: Get TikTok URL via Telegram”,
“type”: “n8n-nodes-base.telegramTrigger”,
“position”: [
80,
80
“webhookId”: “0a5d6208-ff0c-4f0c-8953-cae6a58996bc”,
“typeVersion”: 1.1,
“credentials”: {
“telegramApi”: {
“id”: “EvK0tWbpb7o6FapV”,
“name”: “Telegram account 3”
“parameters”: {
“url”: “=https://tiktok-download-video1.p.rapidapi.com/getVideo?url={{ $json.message.text }}”,
“sendHeaders”: true,
“headerParameters”: {
“parameters”: [
“name”: “x-rapidapi-host”,
“value”: “tiktok-download-video1.p.rapidapi.com”
“name”: “x-rapidapi-key”,
“value”: “25fb9b322amsha3091f2f276805bp106afajsn483e826e5df0”
“options”: {}
“id”: “458297c9-a369-4f9d-b82d-dab5a212c7b9”,
“name”: “Download TikTok Video (RapidAPI)”,
“position”: [
320,
80
“typeVersion”: 4.2
“parameters”: {
“url”: “={{ $json.data.origin_cover }}”,
“options”: {}
“id”: “9f7564b1-7170-4e7a-a9be-ecfc9e86a2d6”,
“name”: “Extract Video Thumbnail”,
“position”: [
540,
80
“typeVersion”: 4.2
“parameters”: {
“method”: “POST”,
“url”: “https://api.cloudinary.com/v1_1/dwslozlrw/image/upload”,
“genericAuthType”: “httpBasicAuth”,
“sendBody”: true,
“contentType”: “multipart-form-data”,
“bodyParameters”: {
“parameters”: [
“parameterType”: “formBinaryData”,
“name”: “file”,
“inputDataFieldName”: “data”
“name”: “upload_preset”,
“value”: “n8n_clone”
“options”: {}
“id”: “5f44d2db-e94a-497e-bfc3-1518dac15d40”,
“name”: “Upload Thumbnail to Cloudinary”,
“position”: [
760,
80
“typeVersion”: 4.2,
“credentials”: {
“httpBasicAuth”: {
“id”: “QiNTngiYPkQDyyso”,
“name”: “Unnamed credential”
“parameters”: {
“resource”: “image”,
“operation”: “analyze”,
“modelId”: {
“__rl”: true,
“mode”: “list”,
“value”: “gpt-4o”,
“cachedResultName”: “GPT-4O”
“imageUrls”: “={{ $json.url }}”,
“options”: {}
“id”: “af8cd879-a515-4af7-a92a-fc04a876e253”,
“name”: “Analyze Thumbnail (GPT-4o Vision)”,
“type”: “@n8n/n8n-nodes-langchain.openAi”,
“position”: [
980,
80
“typeVersion”: 1.8,
“credentials”: {
“openAiApi”: {
“id”: “TmdaFYlr6WkTWFwd”,
“name”: “OpenAi account”
“parameters”: {
“modelId”: {
“__rl”: true,
“mode”: “list”,
“value”: “gpt-4o”,
“messages”: {
“values”: [
“content”: “=Identify and return only the text located at the very top as described by:\n\n{{ $json.content }}\n\n• Return exactly that top-section text, with no quotation marks or extra commentary. \n• If there is no text overlay at the top of the image, return an empty response.\n”
“options”: {}
“id”: “d2bcc2b6-17fe-41f0-b106-2a1267cf3bf6”,
“name”: “Extract Overlay Text (GPT-4o)”,
“position”: [
1200,
80
“typeVersion”: 1.8,
“credentials”: {
“openAiApi”: {
“parameters”: {
“jsCode”: “// Utility to create a random alphanumeric ID\nfunction createUniqueId(length = 12) {\n const characters = ‘ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789’;\n let id = ‘’;\n for (let i = 0; i < length; i++) {\n const randomIndex = Math.floor(Math.random() * characters.length);\n id += characters[randomIndex];\n }\n return id;\n}\n\n// Return the ID in the expected output structure\nreturn [\n {\n json: {\n code: createUniqueId()\n }\n }\n];”
“id”: “e7b3c0e0-0c9f-4458-a21d-8d7a8b4dc5b9”,
“name”: “Generate Unique Template ID”,
“position”: [
2000,
80
“typeVersion”: 2
“parameters”: {
“operation”: “append”,
“documentId”: {
“__rl”: true,
“value”: “COPY THIS: n8n TikTok Video Repurposer - Google Sheets”,
“mode”: “url”
“sheetName”: {
“__rl”: true,
“mode”: “list”,
“value”: “gid=0”,
“cachedResultUrl”: “https://docs.google.com/spreadsheets/d/1SoYJvZbVNn4L1FNfk9eFqx_vGlCsMxgw8bx0DVFgBLY/edit#gid=0”,
“cachedResultName”: “Template”
“columns”: {
“mappingMode”: “defineBelow”,
“value”: {
“Caption”: “={{ $(‘Download TikTok Video (RapidAPI)’).item.json.data.title }}”,
“Video Link”: “={{ $(‘Trigger: Get TikTok URL via Telegram’).item.json.message.text }}”,
“Template ID”: “={{ $json.code }}”,
“Overlay Text Template”: “={{ $(‘Download TikTok Audio1’).item.json.message.content }}”,
“Video Script Template”: “={{ $(‘Transcribe Audio to Script (GPT)1’).item.json.text }}”
“matchingColumns”: ,
“schema”: [
“id”: “Template ID”,
“displayName”: “Template ID”,
“required”: false,
“defaultMatch”: false,
“display”: true,
“type”: “string”,
“canBeUsedToMatch”: true,
“removed”: false
“id”: “Video Link”,
“displayName”: “Video Link”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “Overlay Text Template”,
“displayName”: “Overlay Text Template”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “Video Script Template”,
“displayName”: “Video Script Template”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “Caption”,
“displayName”: “Caption”,
“required”: false,
“display”: true,
“type”: “string”,
“attemptToConvertTypes”: false,
“convertFieldsToString”: false
“options”: {}
“id”: “77ea8050-de65-4468-823a-aca1ac53049a”,
“name”: “Save Original Video to Google Sheets”,
“type”: “n8n-nodes-base.googleSheets”,
“position”: [
2220,
80
“typeVersion”: 4.5
“parameters”: {
“url”: “={{ $(‘Download TikTok Video (RapidAPI)’).item.json.data.music }}”,
“options”: {}
“id”: “ff7d5304-f9f5-4668-9c53-ca280c629ec7”,
“name”: “Download TikTok Audio1”,
“position”: [
1540,
80
“typeVersion”: 4.2
“parameters”: {
“resource”: “audio”,
“operation”: “transcribe”,
“options”: {}
“id”: “80ffccce-dec6-4786-ae7c-d29d996d148e”,
“name”: “Transcribe Audio to Script (GPT)1”,
“position”: [
1780,
80
“typeVersion”: 1.8,
“credentials”: {
“openAiApi”: {
“connections”: {
“Trigger: Get TikTok URL via Telegram”: {
“main”: [
“node”: “Download TikTok Video (RapidAPI)”,
“type”: “main”,
“index”: 0
“Download TikTok Video (RapidAPI)”: {
“main”: [
“node”: “Extract Video Thumbnail”,
“type”: “main”,
“index”: 0
“Extract Video Thumbnail”: {
“main”: [
“node”: “Upload Thumbnail to Cloudinary”,
“type”: “main”,
“index”: 0
“Upload Thumbnail to Cloudinary”: {
“main”: [
“node”: “Analyze Thumbnail (GPT-4o Vision)”,
“type”: “main”,
“index”: 0
“Analyze Thumbnail (GPT-4o Vision)”: {
“main”: [
“node”: “Extract Overlay Text (GPT-4o)”,
“type”: “main”,
“index”: 0
“Extract Overlay Text (GPT-4o)”: {
“main”: [
“node”: “Download TikTok Audio1”,
“type”: “main”,
“index”: 0
“Generate Unique Template ID”: {
“main”: [
“node”: “Save Original Video to Google Sheets”,
“type”: “main”,
“index”: 0
“Save Original Video to Google Sheets”: {
“main”: [
“Download TikTok Audio1”: {
“main”: [
“node”: “Transcribe Audio to Script (GPT)1”,
“type”: “main”,
“index”: 0
“Transcribe Audio to Script (GPT)1”: {
“main”: [
“node”: “Generate Unique Template ID”,
“type”: “main”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “ba9f9132c0ff901e622c6785d60b485c7418ce5b89ccb8f487a01a79db5eba9a”
I’d recommend just using something like Supadata, it will give you ready TikTok captions or transcribe with Whisper if they don’t exist yet. it has a node called n8n-nodes-supadata
Hi, Ebierer. I’d like to know whether your issue has been resolved. I’m facing a similar problem and would like to learn from your experience.
This is my post to address the issue. Thanks.
