Triggers for Supabase (RealTime)
The idea is:
Support for flow triggers from events in supabase, such as database changes, broadcasts (custom events)
My use case:
Running flows based on changes in the database. For example, when a new row is inserted into a table, trigger a flow to process that data or notify users.
Or when a custom event is broadcasted, trigger a flow to handle that event.
Currently for running flows based on database changes you have to use the webhook trigger, and in supabase you have to add a trigger to the database to call the webhook. This is not very user friendly and requires additional setup.
Possibly, but I have not worked with the codebase of n8n before. I would need some guidance on how to implement this feature.
