Troubles with Custom Domain for Webhooks
Im running n8n off a docker container on an ubuntu server.
When I create a webhook it displays “https://n8n./webhook-test/6…”
I have SSH’d into the server and added the following lines to my .env folder WEBHOOK_URL=https://n8n.mydomain.com
and then rebooted the machine and no luck.
Where am i supposed to be putting this line?
Hi @Gavien
Thanks for posting here and welcome to the community! :cake:
Since you’re using docker, the WEBHOOK_URL needs to be loaded from the container when launching. The .env file is supposed to only hold the values that you want your docker environment to be booted with.
So either put it in your docker compose file (recommendation) or you can run the flag when launching the container -e WEBHOOK_URL=https://n8n.mydomain.com
Have a look in our docs:
