Unable to get unique rows using GET function
ONE WORD EXPLANATION: REPETITION
What i tried?
Tried with Supabase using RETURN ALL. Server would stop after a bit of time possibly because of repetition/infinite loop. Tried on two different n8n self hosted setups:
  1. server: 233MB availabl
  2. server: 1.1GB available
encountered same thing across both. Then i thought might be something with supabase, tried google sheets, worked only once. Then i shifted to native data tables and encountering the same issue but this time “REPETITION” is pretty clear.
As far as my data table is concerned, I have 1000 unique rows with 7 columns adding up to almost 7000 data points (size around 0.26mb) which i believe should not be heavy on the server.
Table with thousand unique rows
  • n8n version: Version 1.115.3
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Docker (cloud self-hosted)
RESOLVED. The previous node had 1000 items as output so it was running once for each :slight_smile:
