Unknown error within code node
There is an issue with this workflow I am not sure what the exact problem is, but whenever I am trying to run the entire workflow it stops at random code nodes only and gives unknown error, but if I execute node by node or delete a couple nodes from the end and perform the action - there is no issue.
I have tried everything, not sure if this is a memory issue with N8N cloud or the data being parsed is in the wrong structure/format but I am facing this issue only with this flow, there are multiple other active worklows and none of them have this sort of an issue.
Adding screenshot since character limit was hit while trying to enter the workflow
What’s exactly your code in this node?
This is now sorted, thankyou!
You’re welcome bud!
Feel free to like and mark my message as solution if it’s helpful :slight_smile:
