Using Expression route in Switch node
Hello everyone, I would like to use a Switch Node in Expression Mode (I’ven’t find so much resource online)
I would like to route my input with the following condition:
If attributesName and attributesValue are empty > output 1
If attributesName and attributesValue are NOT empty > output2
Please share the workflow
Input
"email":
"[email protected]",
"attributesName":
"attributesValue":
"email":
"attributesName":
"present",
"attributesValue":
"yes"
"email":
"attributesName":
"attributesValue":
"email":
"attributesName":
"attributesValue":
"email":
"attributesName":
"attributesValue":
"email":
"attributesName":
"oka",
"attributesValue":
"try"
"email":
"test.gregoire.20[email protected]",
"attributesName":
"attributesValue":
  • n8n version: 0.213.0
  • Database you’re using (default: SQLite):
  • Running n8n with the execution process [own(default), main]:
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]: n8n.cloud
Update:
I’ve write this expression that return in output: Output 1 or Output 2
{{$json["attributesName"] || $json["attributesValue"] ? "Output 1" : "Output 2"}}
But there is no output data in this branch
Solved using the Switch like Rules
And then adding the function above in the first value
Glad to see you’ve figured it out already, thanks for sharing your solution :slight_smile:
