Using n8n cloud, can I trigger webhook using telegram
Is there any way I am missing out?
![n8n|607x312](upload://cRjqtuixFQDKMA3818gNqBhJ53L.png)
Could you explain what exactly you are looking to achieve?
Each workflow needs a webhook - this is what starts the workflow:
  • If you want to start the workflow using telegram - you use telegram trigger
  • if you want to start the workflow using webhook - use the the webhook trigger
You don’t need both, so you can’t connect them.
If you want the workflow to start from a telegram message, and then send an http request - then use a telegram webhook and then an http request node.
Please explain what it is you are trying to do.
