View logs of running executions and cancelled executions
The idea is:
Sometimes we get longer running executions and it is not always obvious where they have got stuck. It would be good to view the logs of the running execution in the same way you can see them fro the completed ones.
Also if we then cancel the execution, there are no logs present so again being able to see the logs of the cancelled executions would be good so we can see where it got to.
My use case:
Use case is workflows that acquire documents from various sources, uses ai to analyse and then produce summaries
it would help determine what an execution is doing in real time, or near real time
Not currently
