Hi guys!
I am expiriencing isuess with webhooks. It seems that none of my webhooks is receiving data. I am using n8n on desktop app. When I try to send data to a webhook I get ETIMEDOUT error or 404 error.
Cheers!
Hi guys!
Cheers!
Hi @anze.gracar, I am sorry to hear you’re having trouble. The tunnel used by the desktop app can be troublesome at times and is not meant for production use. If you encounter issues with it, you could in a first step try out the approach suggested here to reset your tunnel: Connect n8n to webhook on desktop app - #2 by MutedJam
Hi @MutedJam, thanks for a quick reply.
I will give it a go, and let you know how it goes,
