I have an issue which my workflow menu or page has “Connection Lost” (as picture below), that resulting I can’t import my workflow file. However the instance is not showing any error on the log:
2025-08-07T07:40:15.085Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
2025-08-07T07:41:15.087Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
2025-08-07T07:42:15.087Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
2025-08-07T07:43:15.088Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
2025-08-07T07:44:15.089Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
2025-08-07T07:45:15.090Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
Okay, I have used your suggested configuration, it seems the websocket error has gone, however I am still getting connection lost on the workflow, can’t import workflow file
2025-08-08T04:11:24.599Z [Rudder] debug: no existing flush timer, creating new one
2025-08-08T04:11:32.370Z | debug | Querying database for waiting executions {"scopes":["waiting-executions"],"file":"wait-tracker.js","function":"getWaitingExecutions"}
2025-08-08T04:11:34.601Z [Rudder] debug: in flush
2025-08-08T04:11:34.601Z [Rudder] debug: cancelling existing flushTimer...
2025-08-08T04:11:37.098Z [Rudder] debug: no existing flush timer, creating new one
2025-08-08T04:11:47.099Z [Rudder] debug: in flush
2025-08-08T04:11:47.099Z [Rudder] debug: cancelling existing flushTimer...
Error fetching feature flags Error [PostHogFetchNetworkError]: Network error while fetching PostHog
at new PostHogFetchNetworkError (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/posthog-node@3.2.1/node_modules/posthog-core/src/index.ts:41:5)
at PostHog.<anonymous> (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/posthog-node@3.2.1/node_modules/posthog-core/src/index.ts:546:17)
at step (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/posthog-node@3.2.1/node_modules/node_modules/tslib/tslib.es6.js:102:23)
at Object.throw (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/posthog-node@3.2.1/node_modules/node_modules/tslib/tslib.es6.js:83:53)
at rejected (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/posthog-node@3.2.1/node_modules/node_modules/tslib/tslib.es6.js:74:65) {
error: DOMException [TimeoutError]: The operation was aborted due to timeout
at node:internal/deps/undici/undici:13510:13,
[cause]: DOMException [TimeoutError]: The operation was aborted due to timeout
ValidationError: The 'X-Forwarded-For' header is set but the Express 'trust proxy' setting is false (default). This could indicate a misconfiguration which would prevent express-rate-limit from accurately identifying users. See https://express-rate-limit.github.io/ERR_ERL_UNEXPECTED_X_FORWARDED_FOR/ for more information.
at Object.xForwardedForHeader (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/express-rate-limit@7.5.0_express@5.1.0/node_modules/express-rate-limit/dist/index.cjs:187:13)
at Object.wrappedValidations.<computed> [as xForwardedForHeader] (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/express-rate-limit@7.5.0_express@5.1.0/node_modules/express-rate-limit/dist/index.cjs:398:22)
at Object.keyGenerator (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/express-rate-limit@7.5.0_express@5.1.0/node_modules/express-rate-limit/dist/index.cjs:671:20)
at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/express-rate-limit@7.5.0_express@5.1.0/node_modules/express-rate-limit/dist/index.cjs:724:32
at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/express-rate-limit@7.5.0_express@5.1.0/node_modules/express-rate-limit/dist/index.cjs:704:5 {
code: 'ERR_ERL_UNEXPECTED_X_FORWARDED_FOR',
help: 'https://express-rate-limit.github.io/ERR_ERL_UNEXPECTED_X_FORWARDED_FOR/'
Its about your kubernetes config and i guess you must be using n8n queue mode on there and it must be config separately.
the easiest way to resolve your issue is try to use helm from this n8n 0.23.0 · riatlas/n8n its helps to learn how to setup n8n on kubernetes cluster or you can try with minim setup with docker compose to figure out all config and env on n8n then customize your needs with kubernetes
# Default values for n8n-service.
# This is a YAML-formatted file.
# Declare variables to be passed into your templates.
# This will set the replicaset count more information can be found here: https://kubernetes.io/docs/concepts/workloads/controllers/replicaset/
replicaCount: 1
# This sets the container image more information can be found here: https://kubernetes.io/docs/concepts/containers/images/
image:
repository: own-hosted-registyr.co..id/dev/n8n
# This sets the pull policy for images.
pullPolicy: IfNotPresent
# Overrides the image tag whose default is the chart appVersion.
tag: "latest"
# This is for the secrets for pulling an image from a private repository more information can be found here: https://kubernetes.io/docs/tasks/configure-pod-container/pull-image-private-registry/
imagePullSecrets:
- name: my-secret
# This is to override the chart name.
nameOverride: ""
fullnameOverride: ""
# This section builds out the service account more information can be found here: https://kubernetes.io/docs/concepts/security/service-accounts/
serviceAccount:
# Specifies whether a service account should be created
create: true
# Automatically mount a ServiceAccount's API credentials?
automount: true
# Annotations to add to the service account
annotations: {}
# The name of the service account to use.
# If not set and create is true, a name is generated using the fullname template
# This is for setting Kubernetes Annotations to a Pod.
# For more information checkout: https://kubernetes.io/docs/concepts/overview/working-with-objects/annotations/
podAnnotations: {}
# This is for setting Kubernetes Labels to a Pod.
# For more information checkout: https://kubernetes.io/docs/concepts/overview/working-with-objects/labels/
podLabels: {}
podSecurityContext: {}
# fsGroup: 2000
securityContext: {}
# capabilities:
# drop:
# - ALL
# readOnlyRootFilesystem: true
# runAsNonRoot: true
# runAsUser: 1000
# This is for setting up a service more information can be found here: https://kubernetes.io/docs/concepts/services-networking/service/
service:
# This sets the service type more information can be found here: https://kubernetes.io/docs/concepts/services-networking/service/#publishing-services-service-types
type: NodePort
# This sets the ports more information can be found here: https://kubernetes.io/docs/concepts/services-networking/service/#field-spec-ports
port: 80
targetPort: 5678
nodePort: 31242
# This block is for setting up the ingress for more information can be found here: https://kubernetes.io/docs/concepts/services-networking/ingress/
ingress:
enabled: true
className: ""
annotations:
kubernetes.io/ingress.class: nginx-intranet
nginx.ingress.kubernetes.io/rewrite-target: /$2
nginx.ingress.kubernetes.io/use-regex: "true"
nginx.ingress.kubernetes.io/server-snippets: |
location / {
proxy_set_header Connection "Upgrade";
hosts:
- host: example.own.domain.co.id
paths:
- path: /n8n(/|$)(.*)
pathType: ImplementationSpecific
tls: []
# - secretName: chart-example-tls
# hosts:
# - chart-example.local
env:
- name: DB_TYPE
value: "postgresdb"
- name: DB_POSTGRESDB_DATABASE
value: "postgres"
- name: DB_POSTGRESDB_HOST
value: "IP"
- name: DB_POSTGRESDB_PORT
value: "5432"
- name: DB_POSTGRESDB_USER
value: "example"
- name: DB_POSTGRESDB_PASSWORD
value: "example"
- name: GENERIC_TIMEZONE
value: "Asia/Jakarta"
- name: N8N_HOST
value: "example.own.domain.co.id"
- name: N8N_PORT
value: "5678"
- name: N8N_PATH
value: "/n8n/"
- name: N8N_LOG_LEVEL
value: "debug"
- name: N8N_COMMUNITY_PACKAGES_ENABLED
value: "false"
resources:
# We usually recommend not to specify default resources and to leave this as a conscious
# choice for the user. This also increases chances charts run on environments with little
# resources, such as Minikube. If you do want to specify resources, uncomment the following
# lines, adjust them as necessary, and remove the curly braces after 'resources:'.
limits:
cpu: 500m
memory: 512Mi
requests:
cpu: 200m
memory: 256Mi
# This is to setup the liveness and readiness probes more information can be found here: https://kubernetes.io/docs/tasks/configure-pod-container/configure-liveness-readiness-startup-probes/
livenessProbe:
httpGet:
path: /
port: http
readinessProbe:
httpGet:
path: /
port: http
# This section is for setting up autoscaling more information can be found here: https://kubernetes.io/docs/concepts/workloads/autoscaling/
autoscaling:
enabled: false
minReplicas: 1
maxReplicas: 100
targetCPUUtilizationPercentage: 80
# targetMemoryUtilizationPercentage: 80
# Additional volumes on the output Deployment definition.
volumes: []
# - name: foo
# secret:
# secretName: mysecret
# optional: false
# Additional volumeMounts on the output Deployment definition.
volumeMounts: []
# - name: foo
# mountPath: "/etc/foo"
# readOnly: true
nodeSelector: {}
tolerations: []
affinity: {}
