Hey my workflow crashed after 225 runs… Because of JSON format, before everything was fine… how can I fix this? Also how can I fix it and start from where I left? I saved the workflow execution…
“errorMessage”: “Expected ‘,’ or ‘}’ after property value in JSON at position 15 (line 2 column 14) [line 8]”,
“errorDescription”: “SyntaxError”,
“errorDetails”: {},
“n8nDetails”: {
“n8nVersion”: “2.2.4 (Self Hosted)”,
“stackTrace”: [
“SyntaxError: Expected ‘,’ or ‘}’ after property value in JSON at position 15 (line 2 column 14)”,
" at JSON.parse ()“,
" at VmCodeWrapper (evalmachine.:8:23)”,
" at evalmachine.:22:2",
" at Script.runInContext (node:vm:149:12)“,
" at runInContext (node:vm:301:6)”,
" at result (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+task-runner@file+packages+@n8n+task-runner_@opentelemetry+api@1.9.0_@opentelemetry_eb51b38615a039445701c88b088f88d0/node_modules/@n8n/task-runner/dist/js-task-runner/js-task-runner.js:185:61)“,
" at new Promise ()”,
" at JsTaskRunner.runForAllItems (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+task-runner@file+packages+@n8n+task-runner_@opentelemetry+api@1.9.0_@opentelemetry_eb51b38615a039445701c88b088f88d0/node_modules/@n8n/task-runner/dist/js-task-runner/js-task-runner.js:178:34)“,
" at JsTaskRunner.executeTask (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@n8n+task-runner@file+packages+@n8n+task-runner_@opentelemetry+api@1.9.0_@opentelemetry_eb51b38615a039445701c88b088f88d0/node_modules/@n8n/task-runner/dist/js-task-runner/js-task-runner.js:128:26)”,
" at process.processTicksAndRejections (node:internal/process/task_queues:105:5)"
