Workflow running and also bugging šŸ¤”ā‰ļø
Hi,
My workflow delivers ā€œschool contentā€.
  • It takes a request in an n8n Form, then an n8n dynamic form (thank you @ria)
  • Use AI,
  • Create a Google Doc.
:white_check_mark: The workflow delivers the content.
BUT the behavior is weird:
:red_question_mark:In test mode, the node ā€œForm next pageā€ seems to run without stopping.
:cross_mark: When the flow finishes a window
- with url ā€œhttps://n8n.sourcinno.com/form-waiting/3019ā€
- displays "502 Bad Gateway - nginx/1.18.0 (Ubuntu)
Do you have any clue on this two topics?
Many thanks in advance
Cheers
  • n8n version: Last
  • Database (default: SQLite): PostGre
  • n8n EXECUTIONS_PROCESS setting (default: own, main):?
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):**docker
  • **Operating system:**windows11
Hey @AyS_0908
I think you’re missing the ā€œform endingā€ node which is required to close out the form flow.
Also just an optional tip, if you want to reduce the ā€œloadingā€ time for users definitely consider using a (non-blocking) subworkflow trigger to run the document creation process in a separate execution. Here’s an example.
Thank you very much @Jim_Le .
While ā€œFormsā€ are very useful, I kind of struggle with their functioning; I don’t know what I customize wrongly but they function differently from a workflow to another (sometimes ā€˜form ending’ required, sometimes not). I have to deep dive.
