Wrong default timezone in workflow settings?
We’re on N8N self-hosted and have set the default timezone, using the environment variable GENERIC_TIMEZONE=Europe/Zurich
When checking this variable in a workflow, the time zone is fetched correctly:
{{$env['GENERIC_TIMEZONE']}} returns Europe/Zurich. :+1:
However, when creating a new workflow, Default - America/New York is displayed in the workflow’s settings.
What am I missing?
    "env": "Europe/Zurich"
Information on our n8n setup
  • n8n version: 1.67.1
  • Operating system: Ubuntu 22.04.5 LTS
Welcome to the community @david.bruehlmeier !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
I tried 1.67.1 and can see the same. However, when checking the latest, 1.70.3, it works as expected. Upgrading the n8n instance should resolve it for you.
On a side note , there is yet another environment, TZ, you might want to utilize during the deployment if not yet, Docker | n8n Docs.
Thank you very much @ihortom! :handshake:
