Zoom-in on specific spot in workflow with mouse wheel
The idea is:
When I want to zoom in on one part (a few nodes) of my workflow, I’d like to merely roll my mouse wheel while my pointer is hovering over the area to zoom into. See how make does it. THIS IS NOT a promo for that douchey make platform which I’m gradually moving away from.
Much easier editing of workflows.
See how make does it. I really want to move all my automations from there because I love so many things about n8n. But this interface needs just a bit more work.
Have you tried clicking CMD/Ctrl while rolling the mouse wheel? Should do exactly what you are asking for.
YES now thanks to you!
What about zooming in and out WITHOUT pressing the key? Why? Because that would be even smoother. There is no point in scrolling the editor area up and down (that’s what happens if commmand/ctrl key is not pressed while wheeling the mouse) = why not just simply let the zoom in and out happen directly. And mostly because many other applications do so. Or have it as a configurable feture.
This is totally fine tuning wish and that tells us only how good n8n already is.
