Ultimate n8n Dev Container (with Debugging, Monitoring & Observability) Dockers
Hey n8n fam :waving_hand:,
I wanted to share my Docker-based full dev container setup I’ve been building to make working with n8n smoother, especially when working with queues, databases, and performance tuning.
:light_bulb: Key Features
:white_check_mark: n8n + n8n-worker (with queue mode support) Disabled in Dockerfile, enable by removing comments
:white_check_mark: PostgreSQL + pgAdmin
:white_check_mark: Redis + RedisInsight
:white_check_mark: Bull Board for queue debugging
:white_check_mark: Prometheus + Grafana for metrics
:white_check_mark: Clean volume separation for data persistence
:white_check_mark: .env-driven configuration for secrets
:white_check_mark: Health checks and restart policies for dev reliability
:spouting_whale: Services
Service Description Port
n8n Main n8n app 5678
n8n-worker Executes jobs in queue mode
PostgreSQL Database backend 5432
pgAdmin PostgreSQL GUI 5050
Redis Queue engine 6379
RedisInsight GUI for Redis debugging 8001
Bull Board Monitor Bull queues (n8n jobs) 3002
Prometheus Metrics collector 9090
Grafana Dashboards for observability 3003
File in folder
For Grafana and Prometheus see here details
docker-compose.yml
version: '3.8'
volumes:
  db_storage:
  n8n_storage:
  redis_storage:
  pgadmin_data:
  prometheus_data:
  grafana_data:
x-shared: &shared
  restart: always
  image: docker.n8n.io/n8nio/n8n
  environment:
    - DB_TYPE=postgresdb
    - DB_POSTGRESDB_HOST=postgres
    - DB_POSTGRESDB_PORT=5432
    - DB_POSTGRESDB_DATABASE=${POSTGRES_DB}
    - DB_POSTGRESDB_USER=${POSTGRES_NON_ROOT_USER}
    - DB_POSTGRESDB_PASSWORD=${POSTGRES_NON_ROOT_PASSWORD}
    ##- EXECUTIONS_MODE=queue
    ##- QUEUE_MODE=redis
    ##- QUEUE_BULL_REDIS_HOST=redis
    ##- QUEUE_BULL_REDIS_PORT=6379
    ##- QUEUE_HEALTH_CHECK_ACTIVE=true
    - N8N_DEFAULT_BINARY_DATA_MODE=filesystem
    - N8N_ENCRYPTION_KEY=${ENCRYPTION_KEY}
    - N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
    - N8N_HOST=localhost
    - N8N_PORT=5678
    - N8N_PROTOCOL=http
    - N8N_BASIC_AUTH_ACTIVE=true
    - N8N_BASIC_AUTH_USER=${N8N_USER}
    - N8N_BASIC_AUTH_PASSWORD=${N8N_PASSWORD}
    - N8N_LOG_OUTPUT=file
    - n8n.log.level=debug
    - N8N_METRICS=true
    - N8N_RUNNERS_ENABLED=true
  links:
    - postgres
    - redis
  volumes:
    - n8n_storage:/home/node/.n8n
  depends_on:
    redis:
      condition: service_healthy
    postgres:
services:
  postgres:
    image: postgres:16
    restart: always
    environment:
      - POSTGRES_USER
      - POSTGRES_PASSWORD
      - POSTGRES_DB
      - POSTGRES_NON_ROOT_USER
      - POSTGRES_NON_ROOT_PASSWORD
    volumes:
      - db_storage:/var/lib/postgresql/data
      - ./init-data.sh:/docker-entrypoint-initdb.d/init-data.sh
    healthcheck:
      test: ['CMD-SHELL', 'pg_isready -h localhost -U ${POSTGRES_USER} -d ${POSTGRES_DB}']
      interval: 5s
      timeout: 5s
      retries: 10
  redis:
    image: redis:6-alpine
    restart: always
    volumes:
      - redis_storage:/data
    healthcheck:
      test: ['CMD', 'redis-cli', 'ping']
      interval: 5s
      timeout: 5s
      retries: 10
  n8n:
    <<: *shared
    ports:
      - 5678:5678
    user: root
  n8n-worker:
    <<: *shared
    command: worker
    depends_on:
      - n8n
  redisinsight:
    image: redislabs/redisinsight:1.14.0
    container_name: redisinsight
    ports:
      - "8001:8001"
    restart: always
    depends_on:
      redis:
  bull-board:
    build:
      context: .
      dockerfile: Dockerfile.bullboard
    container_name: bull-board
    ports:
      - "3002:3002"
    environment:
      - REDIS_HOST=redis
    depends_on:
      redis:
  pgadmin:
    image: dpage/pgadmin4
    container_name: pgadmin
    restart: always
    ports:
      - "5050:80"
    volumes:
      - pgadmin_data:/var/lib/pgadmin
    environment:
      PGADMIN_DEFAULT_EMAIL: admin@example.com
      PGADMIN_DEFAULT_PASSWORD: admin
    depends_on:
      postgres:
  prometheus:
    image: prom/prometheus
    container_name: prometheus
    restart: always
    ports:
      - "9090:9090"
    volumes:
      - prometheus_data:/prometheus
      - ./prometheus.yml:/etc/prometheus/prometheus.yml
    command:
      - '--config.file=/etc/prometheus/prometheus.yml'
    depends_on:
      - n8n
  grafana:
    image: grafana/grafana
    container_name: grafana
    restart: always
    ports:
      - "3003:3000"
    volumes:
      - grafana_data:/var/lib/grafana
    environment:
      - GF_SECURITY_ADMIN_USER=admin
      - GF_SECURITY_ADMIN_PASSWORD=admin
    depends_on:
      - prometheus
FROM node:18-alpine
WORKDIR /app
# Install all necessary packages
RUN npm install express @bull-board/api @bull-board/ui @bull-board/express bull ioredis
# Add the minimal express server
COPY server.js .
EXPOSE 3002
CMD ["node", "server.js"]
server.js
const express = require('express');
const { createBullBoard } = require('@bull-board/api');
const { BullAdapter } = require('@bull-board/api/bullAdapter');
const { ExpressAdapter } = require('@bull-board/express');
const Queue = require('bull');
// Setup the Bull Board UI using Express
const serverAdapter = new ExpressAdapter();
serverAdapter.setBasePath('/ui');
// This must match the queue name and prefix used by n8n
const jobsQueue = new Queue('jobs', {
  redis: {
    host: process.env.REDIS_HOST || 'redis',
    port: 6379,
  prefix: 'bull' // <-- very important: this is what n8n uses
// Register queues with Bull Board
const { addQueue, removeQueue, setQueues, replaceQueues } = createBullBoard({
  queues: [new BullAdapter(jobsQueue)],
  serverAdapter,
// Start the Express server
const app = express();
app.use('/ui', serverAdapter.getRouter());
app.listen(3002, () => {
  console.log('🚀 Bull Board is running at http://localhost:3002/ui');
:handshake: Contributions & Ideas Welcome
Open to suggestions, tweaks, or contributions. If you’re running more services, feel free to extend this setup and share yours!
Cheers,
@King_Samuel_David
btw, I spin up other versions for testing like this:
docker run -d
–name n8n
–user root
-p 0:5678
-v “$(pwd)”:/home/node/.n8n
-e N8N_ENCRYPTION_KEY=‘KEY’
-e N8N_BASIC_AUTH_ACTIVE=false
n8nio/n8n:1.71.0
As someone just figuring this stuff out on his own without much expertise this stuff is just so insightful for my learning journey. Really appreciate you sharing it.
I’ll leave this message so that the post won’t be deleted for a long time
because it’s cool
ahh thanks :slight_smile: hope all going well.
Can anyone help me deploy this Ultimate n8n Dev Container on Portaine
I tried to pull this from GitHub, but can’t deploy, https: //github.com/SkAhasanulla/n8n-dev
If anyone wants to help. Then I’ll give him access to my Portaine dashboard so he can deploy it easily.
I’m hoping to find a solution to my problem from yours. Thanks.
