After Upgrading n8n self-hosted to v2.x, Queue Mode Reliability Much Worse
Hi All,
After upgrading my self-hosted n8n instance to v2.x (in queue mode), I’m noticing that the number of executions that are failing has increased with no material changes to my infrastructure.
I’m not sure why this happened, but there was some sort of fundamental change in the v2.x logic which has bumped my execution error rates from like (1-2% on v1.x) to like (5-20% on v2.x).
Can someone from the development team comment on whether or not this is a known issue and whether there’s any active investigation on resolving this issue?
Thanks!
Hi @Darien_Kindlund,
Have you read through the breaking changes in the documentation to see if there are any changes you need to make to avoid previously working workflows from breaking in version 2?
Also check the migration tool under settings if it is reporting anything you need to action
If yes, then can you share one or two workflow errors here so we can see the type of errors you are now getting
@Wouter_Nigrini , yes, I’ve read through the breaking changes. None of my workflows use sub-workflows, so that’s not the problem.
I’m about 95% confident, though, that this change is likely the culprit (Remove QUEUE_WORKER_MAX_STALLED_COUNT):
Unfortunately, there is nothing I can do to workaround this problem, as this appears to be a fundamental change to how n8n is performing queue retry logic.
Almost ALL of the errors look like this:
Error: This execution failed to be processed too many times and will no longer retry. To allow this execution to complete, please break down your workflow or scale up your workers or adjust your worker settings. at /usr/local/lib/node_modules/n8n/src/workflow-runner.ts:438:15 at processTicksAndRejections (node:internal/process/task_queues:105:5)
These workflows run easily within 5 mins or less, but 20% of the time, these errors get thrown across almost every workflow randomly since upgrading to n8n v2.x.
Please can you share your docker compose. PS; remove any secrets, passwords, etc.
What is the concurrency you have and how many workers are running?
Hi @Wouter_Nigrini , I use Google Cloud Run to deploy the main node as a service – here’s the corresponding YAML for that (sensitive info was REDACTED):
apiVersion: serving.knative.dev/v1
kind: Service
metadata:
  namespace: 'REDACTED'
  selfLink: /apis/serving.knative.dev/v1/namespaces/REDACTED/services/prod-n8n
  uid: REDACTED
  resourceVersion: REDACTED
  generation: 88
  creationTimestamp: '2024-10-10T20:25:03.694424Z'
  labels:
    run.googleapis.com/satisfiesPzs: 'true'
    cloud.googleapis.com/location: us-east4
  annotations:
    serving.knative.dev/creator: darien@REDACTED
    serving.knative.dev/lastModifier: prod-n8n@REDACTED.iam.gserviceaccount.com
    run.googleapis.com/ingress: all
    run.googleapis.com/operation-id: REDACTED
    run.googleapis.com/ingress-status: all
    run.googleapis.com/invoker-iam-disabled: 'true'
    run.googleapis.com/minScale: '1'
    run.googleapis.com/urls: '["https://prod-n8n-REDACTED.us-east4.run.app","https://prod-n8n-REDACTED-uk.a.run.app"]'
spec:
  template:
    metadata:
      labels:
        owner: darien
        purpose: n8n
        team: REDACTED
        client.knative.dev/nonce: REDACTED
        run.googleapis.com/startupProbeType: Custom
      annotations:
        run.googleapis.com/sessionAffinity: 'false'
        run.googleapis.com/vpc-access-egress: private-ranges-only
        autoscaling.knative.dev/minScale: '1'
        n8n.auto.redeploy/start-date: '2026-01-02T18:00:11.497Z'
        run.googleapis.com/execution-environment: gen2
        autoscaling.knative.dev/maxScale: '1'
        run.googleapis.com/network-interfaces: '[{"network":"default","subnetwork":"default","tags":["n8n"]}]'
        run.googleapis.com/cpu-throttling: 'false'
        run.googleapis.com/startup-cpu-boost: 'true'
    spec:
      containerConcurrency: 480
      timeoutSeconds: 900
      serviceAccountName: prod-n8n@REDACTED.iam.gserviceaccount.com
      containers:
      - name: n8n-1
        image: us-east4-docker.pkg.dev/REDACTED/ghcr/n8n-io/n8n:stable
        ports:
        - name: http1
          containerPort: 5678
        env:
        - name: N8N_VERSION
          value: latest
        - name: N8N_USER_FOLDER
          value: /opt/n8n
        - name: NODE_OPTIONS
          value: --max-old-space-size=3072
        - name: GENERIC_TIMEZONE
          value: America/Los_Angeles
        - name: EXECUTIONS_DATA_MAX_AGE
          value: '168'
        - name: EXECUTIONS_DATA_PRUNE
          value: 'true'
        - name: EXECUTIONS_DATA_PRUNE_MAX_COUNT
          value: '100000'
        - name: EXECUTIONS_MODE
          value: queue
        - name: EXECUTIONS_TIMEOUT
          value: '2700'
        - name: EXECUTIONS_TIMEOUT_MAX
          value: '2700'
        - name: N8N_DEFAULT_BINARY_DATA_MODE
          value: database
        - name: N8N_DISABLE_PRODUCTION_MAIN_PROCESS
          value: 'false'
        - name: N8N_EDITOR_BASE_URL
          value: https://n8n.REDACTED
        - name: N8N_HIRING_BANNER_ENABLED
          value: 'false'
        - name: N8N_HOST
          value: n8n.REDACTED
        - name: N8N_LOG_LEVEL
          value: info
        - name: N8N_PROXY_HOPS
          value: '1'
        - name: N8N_PUSH_BACKEND
          value: websocket
        - name: WEBHOOK_URL
        - name: DB_POSTGRESDB_DATABASE
          value: prod-n8n-REDACTED
        - name: DB_POSTGRESDB_HOST
          value: REDACTED.us-east-1.rds.amazonaws.com
        - name: DB_POSTGRESDB_PORT
          value: '5432'
        - name: DB_POSTGRESDB_SCHEMA
          value: public
        - name: DB_POSTGRESDB_SSL_CA
        - name: DB_POSTGRESDB_SSL_REJECT_UNAUTHORIZED
          value: 'false'
        - name: DB_POSTGRESDB_USER
          value: prod-n8n
        - name: DB_TYPE
          value: postgresdb
        - name: N8N_SMTP_HOST
          value: email-smtp.us-east-1.amazonaws.com
        - name: N8N_SMTP_PORT
          value: '465'
        - name: N8N_SMTP_SENDER
          value: noreply-n8n@REDACTED
        - name: N8N_SMTP_USER
          value: REDACTED
        - name: DB_POSTGRESDB_CONNECTION_TIMEOUT
          value: '30000'
        - name: DB_POSTGRESDB_POOL_SIZE
          value: '120'
        - name: N8N_RUNNERS_ENABLED
          value: 'true'
        - name: N8N_RUNNERS_MODE
          value: external
        - name: N8N_RUNNERS_BROKER_PORT
          value: '5679'
        - name: N8N_RUNNERS_BROKER_LISTEN_ADDRESS
          value: 127.0.0.1
        - name: N8N_RUNNERS_TASK_TIMEOUT
          value: '1800'
        - name: N8N_RUNNERS_HEARTBEAT_INTERVAL
          value: '1800'
        - name: N8N_BLOCK_ENV_ACCESS_IN_NODE
          value: 'false'
        - name: N8N_GIT_NODE_DISABLE_BARE_REPOS
          value: 'true'
        - name: NO_COLOR
          value: 'true'
        - name: QUEUE_BULL_REDIS_HOST
          value: 172.REDACTED
        - name: QUEUE_BULL_REDIS_PORT
          value: '6378'
        - name: OFFLOAD_MANUAL_EXECUTIONS_TO_WORKERS
          value: 'true'
        - name: QUEUE_BULL_REDIS_TLS
          value: 'true'
        - name: NODE_EXTRA_CA_CERTS
          value: /opt/n8n-ca/server-ca.pem
        - name: N8N_EVENTBUS_LOGWRITER_LOGBASENAME
          value: audit/n8nEventLog
        - name: QUEUE_WORKER_LOCK_DURATION
          value: '2100000'
        - name: QUEUE_WORKER_LOCK_RENEW_TIME
          value: '60000'
        - name: QUEUE_WORKER_STALLED_INTERVAL
          value: '120000'
        - name: N8N_CONCURRENCY_PRODUCTION_LIMIT
          value: '-1'
        - name: N8N_RESTRICT_FILE_ACCESS_TO
          value: /opt/n8n
        - name: N8N_ENCRYPTION_KEY
          valueFrom:
            secretKeyRef:
              key: latest
        - name: DB_POSTGRESDB_PASSWORD
          valueFrom:
            secretKeyRef:
              key: latest
        - name: N8N_SMTP_PASS
          valueFrom:
            secretKeyRef:
              key: latest
        - name: N8N_RUNNERS_AUTH_TOKEN
          valueFrom:
            secretKeyRef:
              key: latest
        - name: QUEUE_BULL_REDIS_PASSWORD
          valueFrom:
            secretKeyRef:
              key: latest
        resources:
          limits:
            cpu: 2000m
            memory: 4Gi
        volumeMounts:
        - name: prod-n8n
          mountPath: /opt/n8n
        - name: prod-n8n-runners
          mountPath: /opt/n8n-ca
        - name: in-memory-1
          mountPath: /opt/n8n/.n8n/audit
        livenessProbe:
          initialDelaySeconds: 120
          timeoutSeconds: 20
          periodSeconds: 180
          failureThreshold: 3
          httpGet:
            path: /
            port: 5678
        startupProbe:
          initialDelaySeconds: 60
          timeoutSeconds: 45
          periodSeconds: 60
          failureThreshold: 10
          tcpSocket:
            port: 5678
      volumes:
      - name: prod-n8n
        csi:
          driver: gcsfuse.run.googleapis.com
          volumeAttributes:
            bucketName: prod-n8n
        csi:
          readOnly: true
          volumeAttributes:
            bucketName: prod-n8n-runners
      - name: in-memory-1
        emptyDir:
          medium: Memory
          sizeLimit: 20M
  traffic:
  - percent: 100
    latestRevision: true
status:
  observedGeneration: 88
  conditions:
  - type: Ready
    status: 'True'
    lastTransitionTime: '2026-01-02T18:02:09.993294Z'
  - type: ConfigurationsReady
    status: 'True'
    lastTransitionTime: '2026-01-02T18:01:04.134686Z'
  - type: RoutesReady
    status: 'True'
    lastTransitionTime: '2026-01-02T18:02:09.960940Z'
  latestReadyRevisionName: prod-n8n-REDACTED
  latestCreatedRevisionName: prod-n8n-REDACTED
  traffic:
  - revisionName: prod-n8n-00088-2rc
    percent: 100
  url: https://prod-n8n-REDACTED-uk.a.run.app
  address:
For the worker nodes, here’s the corresponding YAML. I specifically set concurrency to be 1, because I have a sidecar container that acts as an external task runner. I usually spin up between 14 to 30 instances of worker nodes (which worked just fine with n8n v1.x):
apiVersion: run.googleapis.com/v1
kind: WorkerPool
metadata:
  selfLink: /apis/run.googleapis.com/v1/namespaces/REDACTED/workerpools/n8n-workers
  uid: REDACTED
  generation: 9948
  creationTimestamp: '2025-10-26T01:20:44.603565Z'
  labels:
  annotations:
    run.googleapis.com/launch-stage: BETA
    run.googleapis.com/scalingMode: manual
    run.googleapis.com/manualInstanceCount: '12'
spec:
  template:
    metadata:
      labels:
      annotations:
        n8n.auto.redeploy/start-date: '2026-01-02T18:15:37.631Z'
        run.googleapis.com/container-dependencies: '{"n8n-runners-1":["n8n-workers-1"]}'
    spec:
      containers:
      - name: n8n-workers-1
        args:
        - worker
        - --concurrency=1
        env:
        - name: N8N_VERSION
          value: latest
          value: /opt/n8n
          value: --max-old-space-size=6144
          value: '168'
          value: 'true'
          value: '100000'
          value: queue
          value: '2700'
          value: '2700'
          value: database
          value: 'true'
          value: 'false'
          value: info
          value: '1'
          value: websocket
          value: prod-n8n-conf
          value: '5432'
          value: public
          value: 'false'
          value: prod-n8n
        - name: DB_TYPE
          value: postgresdb
          value: '465'
          value: REDACTED
          value: '30000'
          value: '6'
          value: 'true'
          value: external
          value: localhost
          value: '5679'
          value: 127.0.0.1
        - name: N8N_RUNNERS_MAX_CONCURRENCY
          value: '4'
          value: '1800'
          value: '1800'
          value: 'false'
          value: 'true'
        - name: NO_COLOR
          value: 'true'
          value: 172.REDACTED
          value: '6378'
        - name: QUEUE_HEALTH_CHECK_ACTIVE
          value: 'true'
          value: 'true'
        - name: N8N_HOST
          value: n8n.REDACTED
        - name: WEBHOOK_URL
          value: '2100000'
          value: '60000'
          value: '120000'
          value: /opt/n8n
          valueFrom:
            secretKeyRef:
              key: latest
          valueFrom:
            secretKeyRef:
              key: latest
          valueFrom:
            secretKeyRef:
              key: latest
          valueFrom:
            secretKeyRef:
              key: latest
          valueFrom:
            secretKeyRef:
              key: latest
        resources:
          limits:
            cpu: '2'
            memory: 8Gi
        volumeMounts:
        - name: prod-n8n-workers
          mountPath: /opt/n8n
        - name: in-memory-1
        livenessProbe:
          initialDelaySeconds: 30
          timeoutSeconds: 10
          periodSeconds: 60
          failureThreshold: 5
          httpGet:
            path: /healthz
            port: 5678
        startupProbe:
          initialDelaySeconds: 20
          timeoutSeconds: 5
          periodSeconds: 30
          failureThreshold: 3
          httpGet:
            path: /healthz/readiness
            port: 5678
      - name: n8n-runners-1
        image: gcr.io/REDACTED/n8n-runners:latest
        env:
        - name: N8N_RUNNERS_TASK_BROKER_URI
          value: http://127.0.0.1:5679
        - name: N8N_RUNNERS_AUTO_SHUTDOWN_TIMEOUT
          value: '15'
        - name: N8N_RUNNERS_LAUNCHER_HEALTH_CHECK_PORT
          value: '5680'
          value: '1'
        - name: N8N_RUNNERS_MAX_OLD_SPACE_SIZE
          value: '6144'
        - name: N8N_RUNNERS_CONFIG_PATH
          value: /opt/n8n-runners/n8n-task-runners.json
          value: '1800'
          value: 'false'
        - name: NO_COLOR
          value: 'true'
        - name: N8N_RUNNERS_HEALTH_CHECK_SERVER_ENABLED
          value: 'true'
        - name: ANTHROPIC_BASE_URL
          value: https://REDACTED
        - name: N8N_RUNNERS_HEALTH_CHECK_SERVER_HOST
          value: 0.0.0.0
          valueFrom:
            secretKeyRef:
              key: latest
        - name: ANTHROPIC_API_KEY
          valueFrom:
            secretKeyRef:
              key: latest
        resources:
          limits:
            cpu: '2'
            memory: 8Gi
        volumeMounts:
          mountPath: /opt/n8n-runners
        livenessProbe:
          initialDelaySeconds: 15
          timeoutSeconds: 10
          periodSeconds: 300
          failureThreshold: 8
          httpGet:
            path: /healthz
            port: 5680
        startupProbe:
          timeoutSeconds: 5
          periodSeconds: 10
          failureThreshold: 12
          httpGet:
            path: /healthz
            port: 5680
      volumes:
        csi:
          volumeAttributes:
            bucketName: prod-n8n-workers
        csi:
          readOnly: true
          volumeAttributes:
      - name: in-memory-1
        emptyDir:
          medium: Memory
          sizeLimit: 20M
  instanceSplits:
  - latestRevision: true
    percent: 100
status:
  observedGeneration: 9948
  conditions:
  - type: Ready
    status: 'True'
    lastTransitionTime: '2026-01-08T21:03:38.789864Z'
  latestReadyRevisionName: REDACTED
  latestCreatedRevisionName: REDACTED
  instanceSplits:
  - revisionName: REDACTED
    percent: 100
I was able to reduce the frequency of these errors by changing these values within my system:
QUEUE_WORKER_LOCK_DURATION 3600000
QUEUE_WORKER_LOCK_RENEW_TIME 120000
QUEUE_WORKER_STALLED_INTERVAL 240000
However, that doesn’t fully solve the problem – it simply reduces the frequency of the problem. I’d really like an n8n developer to chime on how the long-term issue will get resolved.
Hello @Darien_Kindlund and @Wouter_Nigrini.
I hope you guys are doing well.
Thanks for sharing your insights openly in this discussion. I joined this great thread because currently my team and I are experimenting with deploying a self-hosted AWS ECS cluster in queue mode.
Small workflows worked well, but with heavier workflows we’re also experiencing the `Error: This execution failed to be processed too many times and will no longer retry. To allow this execution to complete, please break down your workflow or scale up your workers or adjust your worker settings.` error.
@Darien_Kindlund ⁣Yesterday I tried bumping the default values of the Env Vars you mentioned but to much lower values, and it failed.
I had
        name  = "QUEUE_WORKER_LOCK_DURATION"
        value = "180000"
        name  = "QUEUE_WORKER_LOCK_RENEW_TIME"
        value = "30000"
        name  = "QUEUE_WORKER_STALLED_INTERVAL"
        value = "60000"
Now I used the same values you recommended:
        value = "3600000"
        value = "120000"
        value = "240000"
I’m waiting to give it one more try with these higher values later today.
@Darien_Kindlund I wonder if you managed to pinpoint any other reason for these failures or figured a definitive fix.
In any case, thanks for sharing these insights.
Hi @fmquaglia_ai,
I also found a similar error recently when trying to upload a large file using the Google Drive node. I managed to resolve the issue by adding the following env vars to both my main and worker instances:
      - NODE_OPTIONS=--max-old-space-size=4096
      - N8N_PAYLOAD_SIZE_MAX=134217728
      - QUEUE_EXECUTIONS_DATA_MAX_SIZE=134217728
This sets the memory allocation to 128MB.
Now this all depends on your available memory on the ECS instances as well as what is going on inside of your workflow which is failing. If the above does not resolve your issue, then I would suggest we look at your workflow next, the size and complexity as well as potentially the way you’re handing data through there
Thanks a lot @Wouter_Nigrini that’s useful too.
So far the test is going well.
It processes a large batch of records in pages. It will take a couple of hours but so far is holding up.
Hi @Wouter_Nigrini and @fmquaglia_ai ,
^ I think this just controls how much data you can “pin” in an n8n workflow for testing purposes… I don’t think this env variable is used in production.
^ I don’t see any indicating that env variable is actually used within the n8n codebase … can you provide a pointer to where it’s actually used?
Hi @Darien_Kindlund I think you’re correct actually. I think then it must have been a combination of
NODE*_OPTIONS=–max-old-space-size=4096 and N8N_PAYLOAD_SIZE_*MAX=134217728 which fixed it for me. I had the same error whether i ran the workflow manually or on a scheduler.
Are you still facing the same issue on your end?
Hello,
I encounter the same issue since i upgrade to v2. In v1 this error appeared maybe once or twice a month not it’s nearly every day.
I haven’t set up env var for queue so i will test and let you know if this solve my issue.
Thank for this thread.
@Wouter_Nigrini , yes I’m still seeing the issue; but I have simply masked the errors and layered in additional retry logic. It’s annoying but it works for now.
How to you implement the retry logic ? Because for me when i have this error i can’t retry the workflow and i can’t see the input data of the workflow to retry it
@Kent1 , there are a couple of options:
  1. Implement a smart queuing system like (hookdeck.com) which can retry failed deliveries (assuming your workflow executions run within 60s-3mins each
    OR
  2. Implement a smart error handler, which takes the recent execution and resubmits it if it contains an error.
I just noticed your mention of worker concurrency:
and remembered the recommendations from n8n:
n8n recommends setting concurrency to 5 or higher for your worker instances. Setting low concurrency values with a large numbers of workers can exhaust your database’s connection pool, leading to processing delays and failures.
Have you tried increasing the worker concurrency? I also have a sidecar container running for the external task runner with a concurrency of 10 and don’t experience any problems. I don’t think in-process/in-container concurrency should cause an issue - or are you worried about overwhelming the external task runner?
@all-you-can-pete , I don’t have DB connection pool problems. I specifically want a worker concurrency of 1 due to the workloads I’m running. Each job is intense and requires a dedicated external task runner container. If I run two jobs within the same external task runner container instance, it’s likely the job won’t complete because it’s out of resources.
Fair enough, was more just being hopeful that it was related and would be possible to increase the concurrency as the warning logged is a lot more generic (“CAN LEAD TO AN UNSTABLE ENVIRONMENT”) than the docs explicitly calling out potential DB issues. Appreciate it’s difficult to do tho with intense jobs without running into other resource constraints.
