Aggregate node workflow issue
In my workflow, I am using Aggregate node but its not taking input from previous edit fields5. how to fix this issue.
@jabbson I need your help.
What do you expect to happen here?
There are two distinct branches, - one starting with the gmail trigger and one starting with the chat trigger. The latter one then splits into two distinct sub-branches, depending on the input, so at any given execution only one of these three is active. So going back to my question - what are we aggregating?
@jabbson This workflow I built to extract required email headers, so I am giving the user the option to choose either raw email headers, .eml upload, or directly fetch from the Gmail account.
So, only one flow will execute, which gives the same output as other edit nodes. Here, my request is that when the Gmail trigger flow executes, the aggregate node should take the input from previous edit node5 like other edit nodes which are coming from if node branch.
it does take the input from Edit Fields5
see, 10 items coming in 1 going out.
