The idea is:
Integrated AI coding with n8n
My use case:
It was amazing to use low code frameworks before GenAI. Now, it is not as amazing as before, since we are not able to combine low code frameworks with GenAI , since AI is not able to understand the structure of the n8n workflow for example. What if we can build a custom node on the fly using AI or custom workflow at least with GenAI.
It will be so basic that without this feature , people may switch to better low code frameworks that support this feature.
