Allow/Add SQL operators to use with date related fields
The idea is:
The idea is to reproduce the same behavior for queries as SQL does. If it is not a complicated query it should be allow that operators like LT, LTE, GT, GTE (<,>,<=,>=) only available for numbers would be also nice to have it for datetimes as SQL does.
Also add the operator between
Yes, if it helps and you allow me to do it.
