Beginner to Advanced: How to Start Contributing to n8n?
My goal is to become a serious contributor to the n8n ecosystem and build deep expertise in workflow automation systems.
I’m interested in contributing through:
node development
core platform improvements
Documentation
What would be the most strategic learning and contribution path to grow from a beginner to a recognized contributor within the n8n community?
@Ravi_Kumar2 Here is what the n8n contribution guide states regarding contributions to the official repository:
Please ensure the following:
• Tests are included for any new functionality, logic changes or bug fixes.
• The PR aligns with our contribution guidelines.
Regarding new nodes:
We no longer accept new nodes directly into the core codebase. Instead, we encourage contributors to follow our Community Node Submission Guide to publish nodes independently.
If your node integrates with an AI service that you own or represent, please email nodes@n8n.io and we will be happy to discuss the best approach.`
You can view the complete contributing guidelines here:
Great goal! Here’s a practical path that worked for others in open source communities:
Start with documentation — it’s the easiest entry point and hugely valuable. Fix typos, clarify confusing sections, add missing examples. The n8n docs are on GitHub so you can start with small PRs immediately.
Then move to bug fixes — look for issues tagged “good first issue” on the n8n GitHub repo. These are specifically picked for new contributors.
For node development — start by building a custom node for a service you personally use. That way you’re solving a real problem and staying motivated.
The key is consistency — small contributions every week beats one big contribution every few months. The maintainers notice people who show up regularly!
Good luck on the journey!
Hi @Ravi_Kumar2 Welcome!
First make sure you have proper understanding of n8n and their flows by doing below course:
Also once you are done with that consider reading notes on how n8n NODEs work in here and how to curate them:
And now OKAY you built a node, how to make sure that other people can see how it works? Showcase that in the creators portal below:
And once you are done with all of this now the bigger picture is documentation you can always contribute to n8n docs here:
Hope this helps. (i followed the same map)
