Best way to read/write MS Access Database?
I just pitched a client on using N8N to automate a process that pulls data from their MS Access database, sends it to Docusign to get a signed PDF, and then writes back to Access. N8N is perfect for them because they can install it on site.
It didn’t occur to me that N8N doesn’t have a built in ODBC module until after I hung up.
What’s the best way to query data from Microsoft Access, process it in N8N, and then write back to Access? Am I going to need to use the code module to do this? Yuck. There must be a better way.
Thanks!
Lee
hello @Lee_S
Well, I suppose you have a “bingo” here.
n8n neither has an MS Access node, nor a DocuSign node. It only has some kind of ODBC with the node Extract from file and pure HTTP request node
I’m pretty much assuming I’m going to have to install an ODBC library for Javascript or Python and then use the Code module a lot.
But I wasn’t aware of an ODBC capability in the Extract from File module. Have you (or has anyone) actually used that?
I have used it and it works quite well to extract the table content from the PDF file
Right, but I’m trying to pull data from a Microsoft Access database, not a PDF file. That’s why I need ODBC. I don’t think extract from file does that.
That’s why I’ve said :slight_smile:
some kind of ODBC
