Blocked from running Workflow Evaluations
I cannot run Workflow evaluations on any of my workflows
When trying to run an Evluation I see Limit reached. Your plan includes custom metrics for one workflow only. Upgrade for unlimited use or delete the workflow with existing evaluation runs.
n8n.io - Workflow Automation
I have previously had an Evaluation set up but that workflow has now been deleted for over 24 hours.
I have tried restarting my n8n instance and refreshing the workflows (as well as waiting 24 hours).
I need to be able to run the Evaluation on at least 1 workflow.
  • n8n version: 1.104.1
  • Database (default: SQLite): SQLIte
  • n8n EXECUTIONS_PROCESS setting (default: own, main): ?
Does anyone have an idea of when this will be looked into?
This is now resolved.
