Built a community node for the session ID problem
Hey everyone,
I built a node ‘session ID‘ to solve the challenge of session ID we all seem to run into when building AI Agents.
  1. The Setup Friction: You drop an Agent into a workflow, but it requires a ‘sessionId’ to work. You end up having to write a Code node or find a workaround just to generate a simple UUID string.
  2. The Loop Context Issue: When you put an AI Agent inside a ‘Split In Batches loop’, it treats every item as a brand new conversation. The AI “forgets” the context of the previous items because the session resets.
FlowEngine Session ID node to handle this logic automatically so we can stop writing custom code for it.
What does it do?
It sits right before your AI Agent and manages the session plumbing for you.
Key Features
1. Generate Session ID Great for Webhooks or Chat triggers. It instantly generates a robust UUID v4. You just map it to your Agent, and you’re good to go.
2. Remember Session in Loops This is the main fix for advanced workflows. If you select “Manage Loop Session,” the node checks n8n’s static memory.
  • It forces the AI Agent to use the same Session ID for every item in the loop.
  • This allows your Agent to maintain context across 100s of iterations without “amnesia.”
How to get it
You can install it directly from the Community Nodes panel: n8n-nodes-flowengine
It’s open-source and free. Hope this helps save you some setup time!
Let me know if you have any questions.
