Can't get execution order right
Hi all,
i tried to transport important information to a later stage of the workflow by using a merge-node. In live-mode it turns out, that the merge node does not wait for the second input so the data-merge does not happen and following nodes fail due to missing information.
  • Is there a trick to execute all preceding nodes before the merge node?
  • Can i set the execution order excplicitly somewhere?
  • Or is there a way to keep a list structure across mutliple Notion-Nodes like create Page, get all child blocks etc. (they have fixed output structure).
Thanks in advance.
  • n8n version: latest (beta) 1.45.0
  • n8n EXECUTIONS_PROCESS setting (default: own, main): v1 (recommended)
  • Operating system: windows / chrome
Sorry, i think i just made an error, the lower node was not connected to an input, so it did not start.
