Column id violates not-null constraint yet there is an ID column? Postgres PGVectorstore
When attempting to insert data into my postgres vector store I get “Error inserting: null value in column”id” of relation “ot_notes” violates not null constraint.
I can see in the table view that I have column “id” and that all of the items have a value in them.
I have attempted to drag the column into the field as an expression but still get the same error. I doublechecked that the column name in my table is identical as well.
Hello @ArcReactorKC
Based on your screenshot, the column name is id in the input section. So in the Parameters settings for ID Column Name, expression should be {{ $json.id }}
