Connect Ollama running local to n8n running local (no docker)
I am trying to connect my locally running n8n instance (localhost:5678) to my locally running Ollama instance (localhost:11434)
Error: connect ECONNREFUSED ::1:11434
    at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1607:16) {
  errno: -61,
  code: 'ECONNREFUSED',
  syscall: 'connect',
  address: '::1',
  port: 11434
} undefined
  • **n8n version:n8n@1.59.3
  • **Operating system:MacOS 14.6.1
try replacing localhost with 127.0.0.1. It looks like your system has IPv6 enabled, but ollama isn’t configured to listen on ::1
It worked <3 thank you!
hello im searching how to connect ollama to n8n no docker but im lost can you share the how to or link me to a guide
noob must grow up and need help
thank you in advance
