Course Level 2 Discord webhook not working
My discord webhook for course level 2 is not working.
“errorMessage”: “Cannot read properties of undefined (reading ‘error’)”,
“errorDetails”: {},
“n8nDetails”: {
“n8nVersion”: “1.104.2 (Cloud)”,
“stackTrace”: [
“TypeError: Cannot read properties of undefined (reading ‘error’)”,
" at ExecuteContext.parseDiscordError (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/Discord/v2/helpers/utils.ts:32:30)“,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/Discord/v2/actions/webhook/sendLegacy.operation.ts:153:34)”,
" at processTicksAndRejections (node:internal/process/task_queues:105:5)“,
" at ExecuteContext.router (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/Discord/v2/actions/router.ts:70:17)”,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/Discord/v2/DiscordV2.node.ts:33:10)“,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.29_46e522f8a77ed5eccc0991bfcca21502/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1211:9)”,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.29_46e522f8a77ed5eccc0991bfcca21502/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1581:27",
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.29_46e522f8a77ed5eccc0991bfcca21502/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2157:11"
Same as mine Please solve
Having the same problem!
Can you show your discord node please ?
Same error !
Below the discord node code.
Thanks for any help!
“nodes”: [
“parameters”: {
“authentication”: “webhook”,
“content”: “=I sent the file using email with the label ID {{ $json.id }}. My ID 40963a3514b0ea52aacf86881742f078”,
“options”: {
“wait”: true
“type”: “n8n-nodes-base.discord”,
“typeVersion”: 2,
“position”: [
720,
-272
“id”: “4d89cddc-e669-4167-824e-624bb3fb6edf”,
“name”: “Discord”,
“webhookId”: “77f05c2e-8b5c-46ca-b0f3-8d2742c12a35”,
“credentials”: {
“discordWebhookApi”: {
“id”: “INQn0hos9iOgGSBU”,
“name”: “Discord Webhook account level 2”
“connections”: {},
“pinData”: {},
“meta”: {
“instanceId”: “02d56ae9b1929673465f92ff3e0aae13860882a2d13d30475814364ef331308d”
This morning 10:25, it Works….but I don’t now why…
Hello all, my discord node is not working. I see that people have experienced similar issues in the past. I would appreciate someone pointing me in the right direction for the solution.
