ceskae
June 25, 2026, 6:14am
1
I also encountered the Discord issue that was raised before. I tried checking the previous topics on this but I can’t find a solution.
Can anyone help? Are there new resolutions? Thank you!
n8n version:
Database (default: SQLite):
Operating system:
achamm
June 25, 2026, 6:19am
2
@ceskae my before edit was wrong, I forgot about the academy switch, but the courses were changed so check out learn.n8n.io
Hi @ceskae
Did you read this?
The n8n Academy is here (soft launch)
The first version of the n8n Academy is now live at learn.n8n.io . It is our new home for structured n8n learning: proper courses with hands-on lessons and a clear path from your first workflow to more advanced builds, all in one place instead of scattered across docs and posts. This is a soft launch, so expect a few rough edges. Your feedback shapes what comes next.
Courses
The academy will be launching with 4 courses available to take.
QS101 n8n Quicksta…
Lvl 1 and 2 courses are retired
ceskae
June 25, 2026, 10:58am
4
This is helpful. Will try it. Thanks!
ceskae
June 25, 2026, 10:59am
5
Hi! Yes! This is the website and courses I’m using.
Hi @ceskae ,
Please check this past solution to see if it helps.
Hi Akarsh,
Update: I’ve just tried the webhook and noticed this issue happens when the text message isn’t in the correct format or the input isn’t the right answer, n8n server will reject and respond like that. Please double-check if your message has a similar format:
[4e98de96b6ca491137acc0efxxxxxxx] Regional Sales Summary: Oceania - 999 orders, total: $9999.99
Instruction from the course:
This error message is quite generic, so I can’t tell exactly what is happening. I just know there’s an issue with the Discord webhook. Could you copy and paste your whole workflow here so we can investigate? Alternatively, you could share a screenshot of your configuration on the Discord node, along with a screenshot of the return data from the node right before it.
If the issue persists, please capture screenshots of your configuration in the Discord node and the input from its previous node so that we can investigate further.
P/s: Also please move your post to this sub-category n8n Academy > QS101: n8n Quickstart which helps other students easier to relate and other members can help you quickly on this topic. Thanks
