Data Table node - If Raw Exists - Two way boolean flow request
I tried to use the option “Continue (using error output)” but it doesn’t work.
In many usage, if you are looking “if a raw is present” (or not), you need to do something on both cases.
Now the Table Node can only stop the execution.
Manage true/false output (like an IF node) or Data/error, will greatly reduce the number of nodes required by a flow.
  • n8n version: 1.120.4
  • Running n8n via (Docker, npm, n8n cloud, desktop app): LXC Container
  • Operating system: Debian 12
Maybe just add the other node If row does not exist together
@mohamed3nan
i thought he was proposing a feature request!
giphy
thanks for the suggestion, anyway.
Also a GET RAWS with a way to mange empty results would be great.
