Date conversion from seconds to yyyy-MM-dd works inconsistently.
I have a platform that stores dates in unix format. Number of seconds since epoch, or, number of seconds since 1/1/1970.
The field holds a string, example given:
"date_enroll": "1557767588"
If I hardcode the number, it works.
If I try to reference the information, it errors out.
I have tried various versions, but it hasnt liked any of them. Another field with a date in it works just fine. I’m using this expression in a set node to convert the date.
{{ DateTime.fromSeconds($json.mosyle.date_last_beat, {zone: 'utc'}).toFormat('yyyy-MM-dd HH:mm') }}
That one works, but this one returns ‘undefined.’
{{ DateTime.fromSeconds($json.mosyle.date_enroll, {zone: 'utc'}).toFormat('yyyy-MM-dd HH:mm') }}
The kicker is if I hard code the value, it works. So I feel it’s something to do with the expression, but the expression is the same except for the reference.
Example of working hard coded value:
"value": "{{ $json.mosyle.date_enroll }}"
Various errors. Many irrelevant because it’s the web site telling me my data is in the wrong format.
This is the input JSON.
"mosyle": {
"deviceudid": "0A11E88C-B0B2-5CA8-8A1D-193A06B5EBA5",
"total_disk": 245,
"os": "macOS 15.3.1",
"serial_number": "C02FP2Y6Q05N",
"device_name": "CamilleP MBP M1",
"device_model": "MacBookPro17,1",
"battery": "0.31",
"osversion": "15.3.1",
"date_info": "1742411444",
"carrier": null,
"roaming_enabled": null,
"isroaming": null,
"imei": null,
"meid": null,
"available_disk": 88,
"wifi_mac_address": "A0:78:17:AB:60:8C",
"bluetooth_mac_address": "A0:78:17:AD:78:20",
"is_supervised": "1",
"date_app_info": "1742406757",
"date_last_beat": "2025-03-19 19:10",
"date_last_push": null,
"status": "INSTALLED",
"isActivationLockEnabled": "0",
"isDeviceLocatorServiceEnabled": null,
"isDoNotDisturbInEffect": null,
"isCloudBackupEnabled": null,
"IsNetworkTethered": null,
"needosupdate": null,
"productkeyupdate": null,
"device_type": "COMPUTER",
"lostmode_status": "DISABLED",
"is_muted": "0",
"date_muted": null,
"activation_bypass": null,
"date_media_info": null,
"tags": "fv",
"is_deleted": "0",
"iTunesStoreAccountHash": "q+Nb9uePflsH6PrML9b/Q5BVh+k=",
"iTunesStoreAccountIsActive": "1",
"date_profiles_info": "1742406844",
"ethernet_mac_address": "a0:78:17:ab:60:8c",
"model_name": "MacBook Pro",
"LastCloudBackupDate": null,
"SystemIntegrityProtectionEnabled": "1",
"BuildVersion": "24D70",
"LocalHostName": "camillep-mbp-m1",
"HostName": "camillep-mbp-m1.local",
"OSUpdateSettings": "{\"AutoCheckEnabled\":true,\"AutomaticAppInstallationEnabled\":true,\"AutomaticOSInstallationEnabled\":false,\"AutomaticSecurityUpdatesEnabled\":true,\"BackgroundDownloadEnabled\":true,\"CatalogURL\":\"https:\\/\\/swscan.apple.com\\/content\\/catalogs\\/others\\/index-15-14-13-12-10.16-10.15-10.14-10.13-10.12-10.11-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog.gz\",\"IsDefaultCatalog\":true,\"PreviousScanDate\":\"2025-03-19T17:52:40Z\"}",
"ActiveManagedUsers": "[\"AC08975E-3AFD-467B-9FB9-F0BBA869931E\"]",
"location": null,
"CurrentConsoleManagedUser": "camillepinsonnault",
"date_printers": "1742406765",
"AutoSetupAdminAccounts": "[{\"GUID\":\"A9AC853B-9CB5-4EA2-8D17-D2C5822C9847\",\"shortName\":\"jamfadmin\"}]",
"appleTVid": null,
"asset_tag": null,
"ManagementStatus": "{\"EnrolledViaDEP\":true,\"IsActivationLockManageable\":true,\"IsUserEnrollment\":false,\"UserApprovedEnrollment\":true}",
"OSUpdateStatus": null,
"AvailableOSUpdates": null,
"percent_disk": "0.35918367346939",
"idusermosyle": null,
"idaccount": "1",
"status_login": "LOGGED",
"date_lastlogin": "1728406543",
"date_checkin": "1728406540",
"date_enroll": "1728406543",
"date_checkout": null,
"date_kinfo": "1742411444",
"enrollment_type": "GENERAL",
"userid": null,
"username": null,
"useremail": null,
"usertype": null,
"device_model_name": "MacBook Pro (13-inch, M1, 2020)",
"has_password": null,
"TimeZone": null,
"activation_bypass_mdm": null,
"cpu_model": "Apple M1",
"hasvpn": "Yes",
"installed_memory": "16",
"vpn_status": "Disconnected",
"latitude": null,
"longitude": null,
"open_direct_device_link": "https://mymsp.mosyle.com/#device_d_1_0A11E88C-B0B2-5CA8-8A1D-193A06B5EBA5",
"ServiceSubscriptions": null,
"DeviceAttestationStatus": "Compliant",
"CustomDeviceAttributes": "[{\"Name\":\"No FV Key Escrowed\",\"CustomAttributeUniqueID\":\"custom_cc_No_FV_Key_Escrowed\",\"Value\":\"FileVault is On. Key Set to be Escrowed to: ClearlyRated will store your FileVault Recovery Key.\"},{\"Name\":\"Escrow Buddy authdb Enabled\",\"CustomAttributeUniqueID\":\"custom_cc_Escrow_Buddy_authdb_Enabled\",\"Value\":\"Installed - Auth Enabled\"},{\"Name\":\"Remove Old kGinger Agents\",\"CustomAttributeUniqueID\":\"custom_cc_remove_old_kginger_agents\",\"Value\":\"\\/bin\\/bash: line 22: \\/var\\/bluesky\\/.getHelp: No such file or directory\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nsetremotelogin: remote login is already Off.\\nStarting...\\nRemoved preference to start ARD after reboot.\\nDone.\\nmv: rename \\/etc\\/ssh\\/sshd_config.kadminbackup to \\/etc\\/ssh\\/sshd_config: No such file or directory\\n<dscl_cmd> DS Error: -14009 (eDSUnknownNodeName)\\ndelete: Invalid Path\\nmv: \\/etc\\/ssh\\/sshd_config.kadminbackup: No such file or directory\\nNo receipt for 'com.kginger.remote' found at '\\/'.\\nNo receipt for 'com.mac-msp.bluesky.update' found at '\\/'.\\nNo receipt for 'com.solarwindsmsp.bluesky' found at '\\/'.\\nNo receipt for 'com.solarwindsmsp.bluesky.admin.pkg' found at '\\/'.\\nNo receipt for 'com.solarwindsmsp.bluesky.pkg' found at '\\/'.\\nNo matching processes were found\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nWarning: Expecting a LaunchDaemons path since the command was ran as root. Got LaunchAgents instead.\\n`launchctl bootout` is a recommended alternative.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nWarning: Expecting a LaunchDaemons path since the command was ran as root. Got LaunchAgents instead.\\n`launchctl bootout` is a recommended alternative.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nWarning: Expecting a LaunchDaemons path since the command was ran as root. Got LaunchAgents instead.\\n`launchctl bootout` is a recommended alternative.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nWarning: Expecting a LaunchDaemons path since the command was ran as root. Got LaunchAgents instead.\\n`launchctl bootout` is a recommended alternative.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nWarning: Expecting a LaunchDaemons path since the command was ran as root. Got LaunchAgents instead.\\n`launchctl bootout` is a recommended alternative.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nrm: \\/etc\\/paths.d\\/munki: No such file or directory\\nNo receipt for 'com.github.munkireport' found at '\\/'.\\nNo receipt for 'com.googlecode.munki.admin' found at '\\/'.\\nNo receipt for 'com.googlecode.munki.app' found at '\\/'.\\nNo receipt for 'com.googlecode.munki.app_usage' found at '\\/'.\\nNo receipt for 'com.googlecode.munki.core' found at '\\/'.\\nNo receipt for 'com.googlecode.munki.launchd' found at '\\/'.\\nNo receipt for 'com.googlecode.munki.no-python' found at '\\/'.\\nNo receipt for 'com.googlecode.munki.python' found at '\\/'.\\nNo receipt for 'com.kginger.middleware' found at '\\/'.\\nNo receipt for 'com.kginger.munki-conditions' found at '\\/'.\\nNo receipt for 'com.kginger.munki-conditions-icloudsync' found at '\\/'.\\nNo receipt for 'com.monitoringclient.pkg.check_munkireport_link' found at '\\/'.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nNo receipt for 'com.monitoringclient.pkg.check_folder_sizes' found at '\\/'.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nNo receipt for 'com.github.munkireport' found at '\\/'.\\nNo receipt for 'com.github.munkireport-python2' found at '\\/'.\\nNo receipt for 'io.macadmins.python.recommended' found at '\\/'.\\nNo receipt for 'org.macadmins.python.recommended' found at '\\/'.\\nWarning: Expecting a LaunchDaemons path since the command was ran as root. Got LaunchAgents instead.\\n`launchctl bootout` is a recommended alternative.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nWarning: Expecting a LaunchDaemons path since the command was ran as root. Got LaunchAgents instead.\\n`launchctl bootout` is a recommended alternative.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nNo receipt for 'connectwisecontrol-9d2d93c8fbb990c7' found at '\\/'.\\nNo receipt for 'screenconnect-c000d4275c180f66' found at '\\/'.\\nNo receipt for 'screenconnect-cce341f45450602b' found at '\\/'.\\nUnload failed: 5: Input\\/output error\\nTry running `launchctl bootout` as root for richer errors.\\nNo receipt for 'com.github.grahampugh.erase-install' found at '\\/'.\\nNo receipt for 'com.DetectXScheduler' found at '\\/'.\\nNo receipt for 'com.thirdvantage.DetectXScheduler' found at '\\/'.\\n{"id":"<20241213060553.4f85948d967d595a@mg.kginger.com>","message":"Queued. Thank you."}\\nremoved\"}]",
"altitude": null
"hudu": [
"company_id": 36
Please let me know if I’ve left out some data or I can make anything more clear.
- n8n version: 1.83.2
- Database (default: SQLite): PostgresQL
- n8n EXECUTIONS_PROCESS setting (default: own, main): Default
- Running n8n via (Docker, npm, n8n cloud, desktop app): Docker on Digital Ocean
- Operating system: Ubuntu 22.04
