When running the workflow, Edit Fields outputs NULL for SQL_newDateTime. When manually running the node, output is correct.
- n8n version: 1.29.1
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): Default
