Enable code blocks within nodes to reference common libraries for shared logic
The idea is:
Enable code blocks within nodes to reference common libraries for shared logic.
My use case:
Custom code for transformations or business logic often needs to be reused across nodes. Without common libraries, logic must be manually copied, creating redundancy and inefficiencies.
It reduces redundant code, improves maintainability, and supports Enterprise-grade workflows where shared libraries are essential for scalable and reusable solutions.
  • Examples from other platforms with shared library support - IBM AppconnectEnterprise
Yes
