Since updating to 2.23 I have noticed that the execution insight dashboard has been pulled. This showed execution runs and failures at the workflow level for the past 7/14 days under the PRO plan (10k executions/mo) - now it’s saying to upgrade (possibly to the £144/mo plan?).
Feel it’s a bit sketchy for n8n to have just pulled this feature completely from plans. Whilst I have my own version using the n8n API, this was extremely useful for quickly looking at failed runs.
Is this a silent feature pull from n8n or a bug?
Hi @Malcolm_Gibb
Please reach out to help@n8n.io. This is likely a regression issue (bug)
Thanks, they have confirmed as a bug in 2.23
@Malcolm_Gibb This is a confirmed bug in 2.23, not a feature pull.
n8n themselves confirmed it . The fix is already shipped, update to 2.23.2, which specifically patches ‘Insights page showing license paywall for licensed users.’
Per n8n’s own docs, the Insights dashboard is included on Pro, the plan tiers only differ in date range options, not dashboard access. No need to upgrade.
If you are on Cloud, the fix will roll out automatically. If self hosted, pull 2.23.2+ and you are good.
