Self-hosted N8N 1.85.4
Got a working workflow triggered by webhook.
Attempted to switch to queue mode for better performance
Setup:
Main N8N in Docker on VPS
Worker N8N in Docker on VPS
Redis on VPS
PostgreSQL on VPS
Ubuntu 22
Both N8N instances within containers can connect to Redis and PostgreSQL (this is clear from logs)
Executions stay in ‘queued’ status.
Tried numerous troubleshooting, nothing helps.
Apparently, PostgreSQL is populated with execution in ‘new’ status, but Redis does not (no n8n:queue, but there are other n8n-related data in Redis - to be honest, not sure how it is supposed to look in reality, the required ‘n8n:queue’ is suggestion by chatgpt, it sometimes invents stuff…).
Redis is definitely operating fine, also used by other application on the server.
Both main instance and worker have ‘Querying database for waiting executions’ in logs.
Any help or direction is really appreciated
Thank you
