Forever running execution | missing execution data
Today at 11:20 multiple workflows failed.
Screnshot of Executions
At first, the “dashboard” workflow failed, when executing it in the editor it uses 150 MB ram on the server.
It crashed on the first node:
Screenshot
After that, my uptime workflow run and never stopped running (see Screenshot of Executions above)
(it only has a webhook and a respond to webhook node)
And now the interesting part, the third workflow which failed did not even show any input data:
Screenshot
in the Pipedrive Trigger node:
When trying to retry the failed execution, it gets executed without problems.
It got triggered by the Pipedrive Trigger node.
This instance is hosted on a Hetzner VPS with only N8N.
4GB ram, never saw it exceeding 2 GB
Should I try to Increase old memory?
  • n8n version: 0.222.3
  • Database (default: SQLite): MySQL
  • Operating system: Ubuntu (Windows 11 on Client)
Hi @FelixL - thanks for getting in touch about this!
While the error message suggests that it may be a memory error, it’s hard to know for certain looking at these screenshots. Would you still have server logs available around these executions that you could share? Has this happened before to you where multiple workflows have failed?
Increasing old memory isn’t necessarily a bad idea, but it only really makes sense if the server logs actually show “JavaScript heap out of memory” errors as suggested in the documentation. It’d be better to be sure!
Thanks for the quick response @EmeraldHerald.
I haven’t seen something like that yet. But I just saw that another workflow “failed” a few seconds before the three workflows i already posted:
Interestingly, no node failed in execution.
Which logs would be interesting for you?
the docker logs are filled with data from our crm,but if required I can pm you those.
We wouldn’t be needing your CRM data, so you can redact anything confidential before posting those logs here :+1: That won’t be necessary to include! We just want to see error details around the times that these workflows failed.
Anything before that is just a dump of the execution 63673
{\"recurrencyRules\":[]}},\"pinData\":{}}","success",63673]
execution time: 1593
Failed saving execution data to DB on execution ID 63673
query is slow: UPDATE `execution_entity` SET `status` = ? WHERE ((`id` = ?)) -- PARAMETERS: ["success",63673]
execution time: 11415
query is slow: SELECT `SharedWorkflow`.`workflowId` AS `SharedWorkflow_workflowId`, `SharedWorkflow`.`userId` AS `SharedWorkflow_userId`, `SharedWorkflow__SharedWorkflow_workflow`.`createdAt` AS `SharedWorkflow__SharedWorkflow_workflow_createdAt`, `SharedWorkflow__SharedWorkflow_workflow`.`updatedAt` AS `SharedWorkflow__SharedWorkflow_workflow_updatedAt`, `SharedWorkflow__SharedWorkflow_workflow`.`id` AS `SharedWorkflow__SharedWorkflow_workflow_id`, `SharedWorkflow__SharedWorkflow_workflow`.`name` AS `SharedWorkflow__SharedWorkflow_workflow_name`, `SharedWorkflow__SharedWorkflow_workflow`.`active` AS `SharedWorkflow__SharedWorkflow_workflow_active`, `SharedWorkflow__SharedWorkflow_workflow`.`nodes` AS `SharedWorkflow__SharedWorkflow_workflow_nodes`, `SharedWorkflow__SharedWorkflow_workflow`.`connections` AS `SharedWorkflow__SharedWorkflow_workflow_connections`, `SharedWorkflow__SharedWorkflow_workflow`.`settings` AS `SharedWorkflow__SharedWorkflow_workflow_settings`, `SharedWorkflow__SharedWorkflow_workflow`.`staticData` AS `SharedWorkflow__SharedWorkflow_workflow_staticData`, `SharedWorkflow__SharedWorkflow_workflow`.`pinData` AS `SharedWorkflow__SharedWorkflow_workflow_pinData`, `SharedWorkflow__SharedWorkflow_workflow`.`versionId` AS `SharedWorkflow__SharedWorkflow_workflow_versionId`, `SharedWorkflow__SharedWorkflow_workflow`.`triggerCount` AS `SharedWorkflow__SharedWorkflow_workflow_triggerCount`, `SharedWorkflow__SharedWorkflow_role`.`createdAt` AS `SharedWorkflow__SharedWorkflow_role_createdAt`, `SharedWorkflow__SharedWorkflow_role`.`updatedAt` AS `SharedWorkflow__SharedWorkflow_role_updatedAt`, `SharedWorkflow__SharedWorkflow_role`.`id` AS `SharedWorkflow__SharedWorkflow_role_id`, `SharedWorkflow__SharedWorkflow_role`.`name` AS `SharedWorkflow__SharedWorkflow_role_name`, `SharedWorkflow__SharedWorkflow_role`.`scope` AS `SharedWorkflow__SharedWorkflow_role_scope` FROM `shared_workflow` `SharedWorkflow` LEFT JOIN `workflow_entity` `SharedWorkflow__SharedWorkflow_workflow` ON `SharedWorkflow__SharedWorkflow_workflow`.`id`=`SharedWorkflow`.`workflowId`  LEFT JOIN `role` `SharedWorkflow__SharedWorkflow_role` ON `SharedWorkflow__SharedWorkflow_role`.`id`=`SharedWorkflow`.`roleId`
execution time: 2138
Last session crashed
Failed saving execution data to DB on execution ID 63732
Failed saving execution data to DB on execution ID 63742
n8n ready on 0.0.0.0, port 5678
Version: 0.222.3
Editor is now accessible via:
The crash just happened, do not know yet why, I do not think I’ve any other logs, at least thats all i get from docker.
I’m not too sure from those logs as it’s not quite helping us understand why it failed beyond a database error - do you also have some database logs from around that time that you could share?
I think that was my fault, the error happened in the same moment I wrote the docker logs to a text file. Something weird happened there.
I am just downloading the file (over 3GB) I’ll upload the relevant parts in the evening.
Here is the part from the server log in that timeframe. There are no entry at 11:20 when it happened.
The messages “query is slow” are probably when big executions get saved to the db.
I’ve now disabled “saving execution data” for some workflows where it’s not needed.
the size of those “query is slow:” lines was sometimes > 20 MB.
2023-04-19T11:06:18.093389836Z  query is slow: UPDATE `execution_entity` SET `data` = ?, `mode` = ?, `startedAt` = ?, `stoppedAt` = ?, `finished` = ?, `wor...
2023-04-19T11:06:18.257766392Z  execution time: 1597
2023-04-19T11:06:18.747938562Z  Failed saving execution data to DB on execution ID 63087
2023-04-19T11:06:19.774742099Z  query is slow: UPDATE `execution_entity` SET `status` = ? WHERE ((`id` = ?)) -- PARAMETERS: ["success",63087]
2023-04-19T11:06:19.774781172Z  execution time: 9384
2023-04-19T11:21:18.765579368Z  query is slow: UPDATE `execution_entity` SET `data` = ?, `mode` = ?, `startedAt` = ?, `stoppedAt` = ?, `finished` = ?, `wor...
2023-04-19T11:21:18.914242219Z  execution time: 1558
2023-04-19T11:21:20.669084987Z  query is slow: UPDATE `execution_entity` SET `status` = ? WHERE ((`id` = ?)) -- PARAMETERS: ["success",63146]
2023-04-19T11:21:19.383819353Z  Failed saving execution data to DB on execution ID 63146
2023-04-19T11:21:20.669144609Z  execution time: 9609
n8n event log:
{"__type":"$$EventMessageWorkflow","id":"036bb381-7c51-4b03-9934-6593a0949630","ts":"2023-04-19T11:20:32.523+02:00","eventName":"n8n.workflow.started","message":"n8n.workflow.started","payload":{"executionId":"62664","userId":"312c7cc3-5647-43ed-a929-9a52358ea5e2","workflowId":"6","isManual":false,"workflowName":"n8n Error workflow"}}
{"__type":"$$EventMessageConfirm","confirm":"036bb381-7c51-4b03-9934-6593a0949630","ts":"2023-04-19T11:20:32.528+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"a1ac4b14-7b8b-4efc-aa82-825156263363","ts":"2023-04-19T11:20:33.886+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62663","nodeName":"Error Trigger","workflowId":"6","workflowName":"n8n Error workflow","nodeType":"n8n-nodes-base.errorTrigger"}}
{"__type":"$$EventMessageConfirm","confirm":"a1ac4b14-7b8b-4efc-aa82-825156263363","ts":"2023-04-19T11:20:33.887+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"fa5d7743-3e26-4b95-901e-d742bbea6b7a","ts":"2023-04-19T11:20:33.888+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62663","nodeName":"Error Trigger","workflowId":"6","workflowName":"n8n Error workflow","nodeType":"n8n-nodes-base.errorTrigger"}}
{"__type":"$$EventMessageConfirm","confirm":"fa5d7743-3e26-4b95-901e-d742bbea6b7a","ts":"2023-04-19T11:20:33.889+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"6af93ede-ae41-46b5-b97f-37c4ebf01d21","ts":"2023-04-19T11:20:33.889+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62663","nodeName":"Telegram","workflowId":"6","workflowName":"n8n Error workflow","nodeType":"n8n-nodes-base.telegram"}}
{"__type":"$$EventMessageConfirm","confirm":"6af93ede-ae41-46b5-b97f-37c4ebf01d21","ts":"2023-04-19T11:20:33.890+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"799196e1-549e-4f87-b983-4de7c9337688","ts":"2023-04-19T11:20:34.063+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62664","nodeName":"Error Trigger","workflowId":"6","workflowName":"n8n Error workflow","nodeType":"n8n-nodes-base.errorTrigger"}}
{"__type":"$$EventMessageConfirm","confirm":"799196e1-549e-4f87-b983-4de7c9337688","ts":"2023-04-19T11:20:34.063+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageWorkflow","id":"4bc9da6b-317c-4ed9-8316-92c7a65172e3","ts":"2023-04-19T11:20:34.065+02:00","eventName":"n8n.workflow.started","message":"n8n.workflow.started","payload":{"executionId":"62665","userId":"312c7cc3-5647-43ed-a929-9a52358ea5e2","workflowId":"48","isManual":false,"workflowName":"UptimeKuma heartbeat Endpoint"}}
{"__type":"$$EventMessageConfirm","confirm":"4bc9da6b-317c-4ed9-8316-92c7a65172e3","ts":"2023-04-19T11:20:34.065+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"f74946e7-63de-4c91-aebb-5e4c5c62b7fa","ts":"2023-04-19T11:20:34.067+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62664","nodeName":"Error Trigger","workflowId":"6","workflowName":"n8n Error workflow","nodeType":"n8n-nodes-base.errorTrigger"}}
{"__type":"$$EventMessageConfirm","confirm":"f74946e7-63de-4c91-aebb-5e4c5c62b7fa","ts":"2023-04-19T11:20:34.067+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"58e7956b-b7d6-4834-a7d8-3e7d1e4cf773","ts":"2023-04-19T11:20:34.067+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62664","nodeName":"Telegram","workflowId":"6","workflowName":"n8n Error workflow","nodeType":"n8n-nodes-base.telegram"}}
{"__type":"$$EventMessageConfirm","confirm":"58e7956b-b7d6-4834-a7d8-3e7d1e4cf773","ts":"2023-04-19T11:20:34.068+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"d732f3dd-8790-41aa-98f3-a43f6065d1bd","ts":"2023-04-19T11:20:34.101+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62663","nodeName":"Telegram","workflowId":"6","workflowName":"n8n Error workflow","nodeType":"n8n-nodes-base.telegram"}}
{"__type":"$$EventMessageConfirm","confirm":"d732f3dd-8790-41aa-98f3-a43f6065d1bd","ts":"2023-04-19T11:20:34.102+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageWorkflow","id":"11e91ffe-73d1-4851-97eb-143499a63880","ts":"2023-04-19T11:20:34.112+02:00","eventName":"n8n.workflow.success","message":"n8n.workflow.success","payload":{"executionId":"62663","success":true,"userId":"312c7cc3-5647-43ed-a929-9a52358ea5e2","workflowId":"6","isManual":false,"workflowName":"n8n Error workflow"}}
{"__type":"$$EventMessageConfirm","confirm":"11e91ffe-73d1-4851-97eb-143499a63880","ts":"2023-04-19T11:20:34.112+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"8a759f7c-d9fd-4819-b6ff-9fe3cae290b0","ts":"2023-04-19T11:20:34.243+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62664","nodeName":"Telegram","workflowId":"6","workflowName":"n8n Error workflow","nodeType":"n8n-nodes-base.telegram"}}
{"__type":"$$EventMessageConfirm","confirm":"8a759f7c-d9fd-4819-b6ff-9fe3cae290b0","ts":"2023-04-19T11:20:34.247+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageWorkflow","id":"31e66d7c-92a9-4de7-b6a2-d8e687756145","ts":"2023-04-19T11:20:34.250+02:00","eventName":"n8n.workflow.success","message":"n8n.workflow.success","payload":{"executionId":"62664","success":true,"userId":"312c7cc3-5647-43ed-a929-9a52358ea5e2","workflowId":"6","isManual":false,"workflowName":"n8n Error workflow"}}
{"__type":"$$EventMessageConfirm","confirm":"31e66d7c-92a9-4de7-b6a2-d8e687756145","ts":"2023-04-19T11:20:34.253+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"84505ad1-216a-4435-ac22-fd84bb987ad8","ts":"2023-04-19T11:20:35.978+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62665","nodeName":"Webhook","workflowId":"48","workflowName":"UptimeKuma heartbeat Endpoint","nodeType":"n8n-nodes-base.webhook"}}
{"__type":"$$EventMessageConfirm","confirm":"84505ad1-216a-4435-ac22-fd84bb987ad8","ts":"2023-04-19T11:20:35.978+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"ee03626b-8654-42cd-a29c-94f769dcdc1b","ts":"2023-04-19T11:20:35.979+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62665","nodeName":"Webhook","workflowId":"48","workflowName":"UptimeKuma heartbeat Endpoint","nodeType":"n8n-nodes-base.webhook"}}
{"__type":"$$EventMessageConfirm","confirm":"ee03626b-8654-42cd-a29c-94f769dcdc1b","ts":"2023-04-19T11:20:35.979+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"985aee33-f5ee-4c39-9a1f-13274b0bad49","ts":"2023-04-19T11:20:35.991+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62665","nodeName":"Respond to Webhook","workflowId":"48","workflowName":"UptimeKuma heartbeat Endpoint","nodeType":"n8n-nodes-base.respondToWebhook"}}
{"__type":"$$EventMessageConfirm","confirm":"985aee33-f5ee-4c39-9a1f-13274b0bad49","ts":"2023-04-19T11:20:35.992+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"d257f5c6-67d8-496a-860d-659b919bf868","ts":"2023-04-19T11:20:35.996+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62665","nodeName":"Respond to Webhook","workflowId":"48","workflowName":"UptimeKuma heartbeat Endpoint","nodeType":"n8n-nodes-base.respondToWebhook"}}
{"__type":"$$EventMessageConfirm","confirm":"d257f5c6-67d8-496a-860d-659b919bf868","ts":"2023-04-19T11:20:35.996+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageWorkflow","id":"11fa63d4-199c-46e1-bfe9-a4fbca901c82","ts":"2023-04-19T11:20:36.007+02:00","eventName":"n8n.workflow.success","message":"n8n.workflow.success","payload":{"executionId":"62665","success":true,"userId":"312c7cc3-5647-43ed-a929-9a52358ea5e2","workflowId":"48","isManual":false,"workflowName":"UptimeKuma heartbeat Endpoint"}}
{"__type":"$$EventMessageConfirm","confirm":"11fa63d4-199c-46e1-bfe9-a4fbca901c82","ts":"2023-04-19T11:20:36.007+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageWorkflow","id":"4e08269d-9bd7-4bbd-9137-19816302dc04","ts":"2023-04-19T11:20:41.819+02:00","eventName":"n8n.workflow.started","message":"n8n.workflow.started","payload":{"executionId":"62666","userId":"312c7cc3-5647-43ed-a929-9a52358ea5e2","workflowId":"19","isManual":false,"workflowName":"[PIPEDRIVE] note SMS handler"}}
{"__type":"$$EventMessageConfirm","confirm":"4e08269d-9bd7-4bbd-9137-19816302dc04","ts":"2023-04-19T11:20:41.819+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"e27a0bbc-8ee8-49e5-bfea-28ba52bcb168","ts":"2023-04-19T11:20:43.682+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Pipedrive Trigger","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.pipedriveTrigger"}}
{"__type":"$$EventMessageConfirm","confirm":"e27a0bbc-8ee8-49e5-bfea-28ba52bcb168","ts":"2023-04-19T11:20:43.683+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"6473eba4-2123-4592-95b4-57590f0eb2ee","ts":"2023-04-19T11:20:43.683+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Pipedrive Trigger","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.pipedriveTrigger"}}
{"__type":"$$EventMessageConfirm","confirm":"6473eba4-2123-4592-95b4-57590f0eb2ee","ts":"2023-04-19T11:20:43.683+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"3d45a2bf-cb24-4a8a-a127-28a4071b031c","ts":"2023-04-19T11:20:43.717+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Set trigger text","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"3d45a2bf-cb24-4a8a-a127-28a4071b031c","ts":"2023-04-19T11:20:43.717+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"904125e8-daf6-46a2-94e6-8e6cd6726ef1","ts":"2023-04-19T11:20:43.720+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Set trigger text","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"904125e8-daf6-46a2-94e6-8e6cd6726ef1","ts":"2023-04-19T11:20:43.720+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"1baacf0b-3677-492b-be4c-8336f3abe151","ts":"2023-04-19T11:20:43.735+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Set trigger text1","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"1baacf0b-3677-492b-be4c-8336f3abe151","ts":"2023-04-19T11:20:43.735+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"ec1eddf5-7f9b-4418-8e13-ae7784fd6e56","ts":"2023-04-19T11:20:43.736+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Set trigger text1","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"ec1eddf5-7f9b-4418-8e13-ae7784fd6e56","ts":"2023-04-19T11:20:43.736+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"64d92827-49b8-49af-b87f-f97f7c4bb1a0","ts":"2023-04-19T11:20:43.775+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"#smsbt Beratungstage","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"64d92827-49b8-49af-b87f-f97f7c4bb1a0","ts":"2023-04-19T11:20:43.775+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"05415bc0-2ca5-47d7-bacf-4a168d633e22","ts":"2023-04-19T11:20:43.776+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"#smsbt Beratungstage","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"05415bc0-2ca5-47d7-bacf-4a168d633e22","ts":"2023-04-19T11:20:43.776+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"b3c667c6-809e-4ab3-a342-cfaaece461da","ts":"2023-04-19T11:20:43.793+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"IF","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.if"}}
{"__type":"$$EventMessageConfirm","confirm":"b3c667c6-809e-4ab3-a342-cfaaece461da","ts":"2023-04-19T11:20:43.793+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"1c1eb360-9640-4880-a2aa-12c7cfdec722","ts":"2023-04-19T11:20:43.823+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"IF","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.if"}}
{"__type":"$$EventMessageConfirm","confirm":"1c1eb360-9640-4880-a2aa-12c7cfdec722","ts":"2023-04-19T11:20:43.824+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"f4b71fab-8c90-4abc-9006-73056a201915","ts":"2023-04-19T11:20:43.836+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"IF1","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.if"}}
{"__type":"$$EventMessageConfirm","confirm":"f4b71fab-8c90-4abc-9006-73056a201915","ts":"2023-04-19T11:20:43.837+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"e773a77b-54d2-49c8-9f10-05e1483f3ad4","ts":"2023-04-19T11:20:43.840+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"IF1","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.if"}}
{"__type":"$$EventMessageConfirm","confirm":"e773a77b-54d2-49c8-9f10-05e1483f3ad4","ts":"2023-04-19T11:20:43.840+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"2a62fb4e-b0bf-40f5-90b2-745c51dabe41","ts":"2023-04-19T11:20:43.855+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"IF2","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.if"}}
{"__type":"$$EventMessageConfirm","confirm":"2a62fb4e-b0bf-40f5-90b2-745c51dabe41","ts":"2023-04-19T11:20:43.856+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"d1cbe190-a97a-48b7-8071-2e32d8b3a235","ts":"2023-04-19T11:20:43.859+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"IF2","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.if"}}
{"__type":"$$EventMessageConfirm","confirm":"d1cbe190-a97a-48b7-8071-2e32d8b3a235","ts":"2023-04-19T11:20:43.859+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"9bb69491-c7bc-41e5-b918-189b692ad65b","ts":"2023-04-19T11:20:43.874+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"setinput","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"9bb69491-c7bc-41e5-b918-189b692ad65b","ts":"2023-04-19T11:20:43.874+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"e9b8d0fa-e3a4-4f0f-9d97-91caf2b2ef48","ts":"2023-04-19T11:20:43.875+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"setinput","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"e9b8d0fa-e3a4-4f0f-9d97-91caf2b2ef48","ts":"2023-04-19T11:20:43.875+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"1f25d40a-6609-4e86-99c5-e5f169c6035c","ts":"2023-04-19T11:20:43.891+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Pipedrive","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.pipedrive"}}
{"__type":"$$EventMessageConfirm","confirm":"1f25d40a-6609-4e86-99c5-e5f169c6035c","ts":"2023-04-19T11:20:43.891+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"2600befb-1748-43a4-b0a7-849f769eecca","ts":"2023-04-19T11:20:44.132+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Pipedrive","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.pipedrive"}}
{"__type":"$$EventMessageConfirm","confirm":"2600befb-1748-43a4-b0a7-849f769eecca","ts":"2023-04-19T11:20:44.135+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"4dd027b4-f103-4eee-8400-a5c39f19e74b","ts":"2023-04-19T11:20:44.148+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Get phone number to use","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"4dd027b4-f103-4eee-8400-a5c39f19e74b","ts":"2023-04-19T11:20:44.149+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"9dae286a-a443-4225-b64b-afbc484f8c8e","ts":"2023-04-19T11:20:44.154+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Get phone number to use","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"9dae286a-a443-4225-b64b-afbc484f8c8e","ts":"2023-04-19T11:20:44.154+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"dc1fa69f-fee2-4252-aba0-a857a493e5ac","ts":"2023-04-19T11:20:44.171+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"HTTP Request4","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.httpRequest"}}
{"__type":"$$EventMessageConfirm","confirm":"dc1fa69f-fee2-4252-aba0-a857a493e5ac","ts":"2023-04-19T11:20:44.171+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"0fb40e45-5a67-4fd2-bef0-bcf105ee96c4","ts":"2023-04-19T11:20:44.315+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"HTTP Request4","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.httpRequest"}}
second part of n8n event log:
{"__type":"$$EventMessageConfirm","confirm":"0fb40e45-5a67-4fd2-bef0-bcf105ee96c4","ts":"2023-04-19T11:20:44.315+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"8e9ed3a8-a579-4b8a-a41a-4e0cfa283a22","ts":"2023-04-19T11:20:44.331+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"IF3","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.if"}}
{"__type":"$$EventMessageConfirm","confirm":"8e9ed3a8-a579-4b8a-a41a-4e0cfa283a22","ts":"2023-04-19T11:20:44.332+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"f029dd60-5c13-4b0e-895a-a8f33d4b8d71","ts":"2023-04-19T11:20:44.336+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"IF3","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.if"}}
{"__type":"$$EventMessageConfirm","confirm":"f029dd60-5c13-4b0e-895a-a8f33d4b8d71","ts":"2023-04-19T11:20:44.337+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"e92e734f-49a9-4345-a021-481fd445055d","ts":"2023-04-19T11:20:44.352+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Set","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"e92e734f-49a9-4345-a021-481fd445055d","ts":"2023-04-19T11:20:44.352+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"b87ecc10-5fa1-4449-97ed-3b3d8e0d683f","ts":"2023-04-19T11:20:44.354+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Set","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"b87ecc10-5fa1-4449-97ed-3b3d8e0d683f","ts":"2023-04-19T11:20:44.354+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"7dffb25c-e5e7-478c-ad75-a4e29e23ab51","ts":"2023-04-19T11:20:44.369+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Switch1","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.switch"}}
{"__type":"$$EventMessageConfirm","confirm":"7dffb25c-e5e7-478c-ad75-a4e29e23ab51","ts":"2023-04-19T11:20:44.369+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"c2c1d4f4-6d2e-47a4-b513-5ebbf97462bd","ts":"2023-04-19T11:20:44.372+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Switch1","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.switch"}}
{"__type":"$$EventMessageConfirm","confirm":"c2c1d4f4-6d2e-47a4-b513-5ebbf97462bd","ts":"2023-04-19T11:20:44.373+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"ad465896-8f3e-4a84-8202-4a4d0b1efb61","ts":"2023-04-19T11:20:44.389+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"MySQL1","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.mySql"}}
{"__type":"$$EventMessageConfirm","confirm":"ad465896-8f3e-4a84-8202-4a4d0b1efb61","ts":"2023-04-19T11:20:44.389+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"a781fdcf-fb67-4d4e-a792-3f6c21198ba0","ts":"2023-04-19T11:20:44.409+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"MySQL1","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.mySql"}}
{"__type":"$$EventMessageConfirm","confirm":"a781fdcf-fb67-4d4e-a792-3f6c21198ba0","ts":"2023-04-19T11:20:44.409+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"8fdbd40c-9449-4272-b706-8faf82d415cd","ts":"2023-04-19T11:20:44.424+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Set Message","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"8fdbd40c-9449-4272-b706-8faf82d415cd","ts":"2023-04-19T11:20:44.424+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"845d5c1f-9668-4d6a-8e57-7f2673b05f65","ts":"2023-04-19T11:20:44.425+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Set Message","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"845d5c1f-9668-4d6a-8e57-7f2673b05f65","ts":"2023-04-19T11:20:44.425+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"1b783ba5-b9a1-4c09-9389-85a4471f0651","ts":"2023-04-19T11:20:44.439+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"setmessagehard","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"1b783ba5-b9a1-4c09-9389-85a4471f0651","ts":"2023-04-19T11:20:44.439+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"43ae9096-7772-4185-b55b-22fbc2b01341","ts":"2023-04-19T11:20:44.440+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"setmessagehard","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"43ae9096-7772-4185-b55b-22fbc2b01341","ts":"2023-04-19T11:20:44.440+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"63742a82-53a2-4cef-baca-dcbd2d9ce263","ts":"2023-04-19T11:20:44.456+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"[TYNTEC] Send SMS","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.httpRequest"}}
{"__type":"$$EventMessageConfirm","confirm":"63742a82-53a2-4cef-baca-dcbd2d9ce263","ts":"2023-04-19T11:20:44.456+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"d396d9fe-f488-436d-8d9f-97454db36373","ts":"2023-04-19T11:20:44.675+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"[TYNTEC] Send SMS","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.httpRequest"}}
{"__type":"$$EventMessageConfirm","confirm":"d396d9fe-f488-436d-8d9f-97454db36373","ts":"2023-04-19T11:20:44.675+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"60da7c9c-6da1-472e-a7df-4205f1db472c","ts":"2023-04-19T11:20:44.693+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Note SMS gets send","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.pipedrive"}}
{"__type":"$$EventMessageConfirm","confirm":"60da7c9c-6da1-472e-a7df-4205f1db472c","ts":"2023-04-19T11:20:44.693+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"90c35de6-8b8c-484d-822b-5101d2f63cde","ts":"2023-04-19T11:20:44.977+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Note SMS gets send","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.pipedrive"}}
{"__type":"$$EventMessageConfirm","confirm":"90c35de6-8b8c-484d-822b-5101d2f63cde","ts":"2023-04-19T11:20:44.978+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"87767a29-91e2-4a5f-be5d-d408c97935cc","ts":"2023-04-19T11:20:44.997+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Set wait time","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"87767a29-91e2-4a5f-be5d-d408c97935cc","ts":"2023-04-19T11:20:44.997+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"c51ea21c-a226-432e-baa3-9f5b890f0235","ts":"2023-04-19T11:20:44.997+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Set wait time","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"c51ea21c-a226-432e-baa3-9f5b890f0235","ts":"2023-04-19T11:20:44.998+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"5bd66c89-2f85-4846-bb28-0b95a002e52f","ts":"2023-04-19T11:20:45.015+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Set6","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"5bd66c89-2f85-4846-bb28-0b95a002e52f","ts":"2023-04-19T11:20:45.016+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"5ceca548-d3b5-4006-8feb-6c7a13cd1c2e","ts":"2023-04-19T11:20:45.022+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Set6","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"5ceca548-d3b5-4006-8feb-6c7a13cd1c2e","ts":"2023-04-19T11:20:45.023+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"4014ea34-ac84-465a-a2ce-77d1cdc23f14","ts":"2023-04-19T11:20:45.037+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Wait","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.wait"}}
{"__type":"$$EventMessageConfirm","confirm":"4014ea34-ac84-465a-a2ce-77d1cdc23f14","ts":"2023-04-19T11:20:45.038+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageAudit","id":"83ce9056-842e-499b-822a-2bc4680ebfc7","ts":"2023-04-19T11:20:47.297+02:00","eventName":"n8n.audit.workflow.updated","message":"n8n.audit.workflow.updated","payload":{"userId":"312c7cc3-5647-43ed-a929-9a52358ea5e2","_email":null,"_firstName":null,"_lastName":null,"globalRole":"owner","workflowId":"56","workflowName":"My workflow 16"}}
{"__type":"$$EventMessageConfirm","confirm":"83ce9056-842e-499b-822a-2bc4680ebfc7","ts":"2023-04-19T11:20:47.298+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"3b2fefe4-364c-4e75-ad9a-44b137988153","ts":"2023-04-19T11:20:55.042+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Wait","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.wait"}}
{"__type":"$$EventMessageConfirm","confirm":"3b2fefe4-364c-4e75-ad9a-44b137988153","ts":"2023-04-19T11:20:55.042+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"74ab4777-aa64-4751-8bc3-5ae99ff191ab","ts":"2023-04-19T11:20:55.063+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"MySQL","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.mySql"}}
{"__type":"$$EventMessageConfirm","confirm":"74ab4777-aa64-4751-8bc3-5ae99ff191ab","ts":"2023-04-19T11:20:55.063+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"9f1fb476-4e0e-4459-a460-b4370e9d52c3","ts":"2023-04-19T11:20:55.074+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"MySQL","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.mySql"}}
{"__type":"$$EventMessageConfirm","confirm":"9f1fb476-4e0e-4459-a460-b4370e9d52c3","ts":"2023-04-19T11:20:55.074+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"e38e6094-b58b-42fc-a883-c3a6673e1e5a","ts":"2023-04-19T11:20:55.089+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"[TYNTEC] Get SMS state 01","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.httpRequest"}}
{"__type":"$$EventMessageConfirm","confirm":"e38e6094-b58b-42fc-a883-c3a6673e1e5a","ts":"2023-04-19T11:20:55.089+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"3dd07f5d-b0d0-4f14-a0b7-fe3e0e416dc0","ts":"2023-04-19T11:20:55.172+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"[TYNTEC] Get SMS state 01","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.httpRequest"}}
{"__type":"$$EventMessageConfirm","confirm":"3dd07f5d-b0d0-4f14-a0b7-fe3e0e416dc0","ts":"2023-04-19T11:20:55.172+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"7d6fd6ff-7e24-4a8a-9a66-faf57b1738f7","ts":"2023-04-19T11:20:55.186+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Set2","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"7d6fd6ff-7e24-4a8a-9a66-faf57b1738f7","ts":"2023-04-19T11:20:55.186+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"e5f7e342-0f5d-426f-bd0a-9d83608bcad5","ts":"2023-04-19T11:20:55.190+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Set2","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"e5f7e342-0f5d-426f-bd0a-9d83608bcad5","ts":"2023-04-19T11:20:55.190+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"480bd4ab-5f15-426f-a419-8d1a32b3566a","ts":"2023-04-19T11:20:55.208+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Set3","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"480bd4ab-5f15-426f-a419-8d1a32b3566a","ts":"2023-04-19T11:20:55.208+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"01a33d30-aacd-4e8c-8400-30b9173feb67","ts":"2023-04-19T11:20:55.212+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Set3","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.set"}}
{"__type":"$$EventMessageConfirm","confirm":"01a33d30-aacd-4e8c-8400-30b9173feb67","ts":"2023-04-19T11:20:55.212+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"757ab3cb-4d96-4cfe-9543-287a679c9fb1","ts":"2023-04-19T11:20:55.226+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"MySQL2","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.mySql"}}
{"__type":"$$EventMessageConfirm","confirm":"757ab3cb-4d96-4cfe-9543-287a679c9fb1","ts":"2023-04-19T11:20:55.226+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"494f1b48-ca4f-4955-9307-389820825027","ts":"2023-04-19T11:20:55.237+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"MySQL2","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.mySql"}}
{"__type":"$$EventMessageConfirm","confirm":"494f1b48-ca4f-4955-9307-389820825027","ts":"2023-04-19T11:20:55.237+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"42493ded-69e8-4bb1-9b47-f1df4731eaef","ts":"2023-04-19T11:20:55.254+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62666","nodeName":"Switch","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.switch"}}
{"__type":"$$EventMessageConfirm","confirm":"42493ded-69e8-4bb1-9b47-f1df4731eaef","ts":"2023-04-19T11:20:55.254+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"0322cec0-4b95-4935-9998-400bcb5b7d1e","ts":"2023-04-19T11:20:55.255+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62666","nodeName":"Switch","workflowId":"19","workflowName":"[PIPEDRIVE] note SMS handler","nodeType":"n8n-nodes-base.switch"}}
{"__type":"$$EventMessageConfirm","confirm":"0322cec0-4b95-4935-9998-400bcb5b7d1e","ts":"2023-04-19T11:20:55.255+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageWorkflow","id":"0b31a4f6-8957-466b-b23f-096c428527e5","ts":"2023-04-19T11:20:55.280+02:00","eventName":"n8n.workflow.success","message":"n8n.workflow.success","payload":{"executionId":"62666","success":true,"userId":"312c7cc3-5647-43ed-a929-9a52358ea5e2","workflowId":"19","isManual":false,"workflowName":"[PIPEDRIVE] note SMS handler"}}
{"__type":"$$EventMessageConfirm","confirm":"0b31a4f6-8957-466b-b23f-096c428527e5","ts":"2023-04-19T11:20:55.284+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageWorkflow","id":"d770a4a7-94ea-404e-8f35-4cebf60e0687","ts":"2023-04-19T11:20:56.285+02:00","eventName":"n8n.workflow.started","message":"n8n.workflow.started","payload":{"executionId":"62667","userId":"312c7cc3-5647-43ed-a929-9a52358ea5e2","workflowId":"48","isManual":false,"workflowName":"UptimeKuma heartbeat Endpoint"}}
{"__type":"$$EventMessageConfirm","confirm":"d770a4a7-94ea-404e-8f35-4cebf60e0687","ts":"2023-04-19T11:20:56.285+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"4e1d0379-53e8-4d06-a9f1-21b9ab145bbb","ts":"2023-04-19T11:20:58.032+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62667","nodeName":"Webhook","workflowId":"48","workflowName":"UptimeKuma heartbeat Endpoint","nodeType":"n8n-nodes-base.webhook"}}
{"__type":"$$EventMessageConfirm","confirm":"4e1d0379-53e8-4d06-a9f1-21b9ab145bbb","ts":"2023-04-19T11:20:58.032+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"2618104c-5661-45b5-8860-d54ea54144e2","ts":"2023-04-19T11:20:58.033+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62667","nodeName":"Webhook","workflowId":"48","workflowName":"UptimeKuma heartbeat Endpoint","nodeType":"n8n-nodes-base.webhook"}}
{"__type":"$$EventMessageConfirm","confirm":"2618104c-5661-45b5-8860-d54ea54144e2","ts":"2023-04-19T11:20:58.034+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"9bb57226-93a3-4565-b3da-7e7d176f3483","ts":"2023-04-19T11:20:58.050+02:00","eventName":"n8n.node.started","message":"n8n.node.started","payload":{"executionId":"62667","nodeName":"Respond to Webhook","workflowId":"48","workflowName":"UptimeKuma heartbeat Endpoint","nodeType":"n8n-nodes-base.respondToWebhook"}}
{"__type":"$$EventMessageConfirm","confirm":"9bb57226-93a3-4565-b3da-7e7d176f3483","ts":"2023-04-19T11:20:58.050+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageNode","id":"d367bf2e-bbd8-4105-b1c3-123522b290f8","ts":"2023-04-19T11:20:58.057+02:00","eventName":"n8n.node.finished","message":"n8n.node.finished","payload":{"executionId":"62667","nodeName":"Respond to Webhook","workflowId":"48","workflowName":"UptimeKuma heartbeat Endpoint","nodeType":"n8n-nodes-base.respondToWebhook"}}
{"__type":"$$EventMessageConfirm","confirm":"d367bf2e-bbd8-4105-b1c3-123522b290f8","ts":"2023-04-19T11:20:58.057+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageWorkflow","id":"0ef03f44-ffdc-4f24-95ce-cd9dae3912d8","ts":"2023-04-19T11:20:58.087+02:00","eventName":"n8n.workflow.success","message":"n8n.workflow.success","payload":{"executionId":"62667","success":true,"userId":"312c7cc3-5647-43ed-a929-9a52358ea5e2","workflowId":"48","isManual":false,"workflowName":"UptimeKuma heartbeat Endpoint"}}
{"__type":"$$EventMessageConfirm","confirm":"0ef03f44-ffdc-4f24-95ce-cd9dae3912d8","ts":"2023-04-19T11:20:58.087+02:00","source":{"id":"0","name":"eventBus"}}
{"__type":"$$EventMessageWorkflow","id":"9a2e2880-0163-4c41-913f-2acf1d7cbc1c","ts":"2023-04-19T11:21:18.486+02:00","eventName":"n8n.workflow.started","message":"n8n.workflow.started","payload":{"executionId":"62668","userId":"312c7cc3-5647-43ed-a929-9a52358ea5e2","workflowId":"48","isManual":false,"workflowName":"UptimeKuma heartbeat Endpoint"}}
Hi @FelixL - thanks so much for sharing this. You’ve provided the n8n logs, but it looks like the problem is actually in the database. Could you provide those logs as well, obviously redacting any data you need?
This was still helpful as we can see that n8n is unable to access the database, but it’s not quite providing the reason. It could be a timeout, you could be out of space, etc. so this would be really helpful!
Hi @EmeraldHerald, my MySQL server did not throw any errors in the timeframe, actually there aren’t any log entries in that timeframe.
Definitely not out of space, already learned my lesson there ^^
If it happens again, I’ll update the thread.
