Hello,
Has anyone tried to connect gemini google with n8n?
Do you know a process?
- **n8n version:1.27.2,
- Database (default: SQLite):
- **Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
- Operating system:
@Arnaudfpm hi brother here is method i have given with sample workflow check that
Thansk you,
I’m a beginner. I’d like to know how you do it in the beginning? Do you have to activate the Generative Language API ?
Then you have to create a JSON or an identification key?
Hello,
For the url i use this like for example :https://generativelanguage.googleapis.com/v1beta/models/gemini-pro:generateContent
then i enable the API
but when i test i have an error message
Someone can explain me pls ?
