I am using a self-hosted n8n instance on a server, and everything seems to be working fine. The server has an authentication SSO interstitial page, so a webhook from the outside is probably not going to be able to contact n8n unless I whitelist it first.
I created the GitHub app and added a token as well. However, no matter how I try to create a trigger, I can’t get it working. If I add a trigger, enter my repo/user name and press “run node”, I get an error 500 (not 404):
Problem running workflow
There was a problem running the workflow: The resource you are requesting could not be found
Sure. The easiest way to check if that is the actual problem would be to test with another repository of which you are the owner for sure. If you then listen for example for stars, you can test very fast and easily if that works there.
