Help Connection lost
Attached is a screenshot of the error I’m getting when trying to run n8n locally using Docker Compose. This error doesn’t appear in Firefox. I’m running it on Ubuntu, and I’ve also installed a local Nginx instance. These are my configurations:
=> .env
:key: Configuraciones del Host Externo (para Webhooks y Browser)
WEBHOOK_URL=https://n8n.local
N8N_BASE_URL=https://n8n.local
VUE_APP_URL_BASE_API=https://n8n.local
:spouting_whale: Configuraciones Internas (para Docker)
N8N_HOST=0.0.0.0
N8N_PORT=5678
:gear: Configuraciones de protocolo
N8N_PROTOCOL=https
N8N_PUSH_BACKEND=websocket
:locked_with_key: Configuración de proxy
N8N_TRUST_PROXY=true
N8N_SECURE_COOKIE=true
:stopwatch: Opcional
TZ=America/Santiago
N8N_ENCRYPTION_KEY=tu_clave_secreta_aqui
=> docker-compose.yml
version: “3.8”
services:
n8n:
image: docker.n8n.io/n8nio/n8n:stable
restart: always
ports:
- “127.0.0.1:5678:5678”
env_file:
- .env
environment:
# Variables críticas adicionales
- N8N_TRUST_PROXY=true
- N8N_SECURE_COOKIE=true
volumes:
- n8n_data:/home/node/.n8n
volumes:
n8n_data:
=> Nginx Configuration
:locked: 1. Bloque para redireccionar HTTP (Puerto 80) a HTTPS
server {
listen 80;
server_name n8n.local;
return 301 https://$host$request_uri;
:locked: 2. Bloque Principal HTTPS (Puerto 443)
server {
listen 443 ssl;
# Rutas a tus certificados auto-firmados
ssl_certificate /docker/n8n-local/ssl/n8n.local.crt;
ssl_certificate_key /docker/n8n-local/ssl/n8n.local.key;
# Configuración de seguridad SSL recomendada
ssl_protocols TLSv1.2 TLSv1.3;
ssl_ciphers HIGH:!aNULL:!MD5;
ssl_prefer_server_ciphers on;
add_header Strict-Transport-Security “max-age=63072000; includeSubDomains; preload” always;
# :fire: CONFIGURACIÓN CORREGIDA PARA WEBSOCKETS
location / {
    # 🔄 CRÍTICO: Versión HTTP 1.1 para WebSockets
    proxy_http_version 1.1;
    # 🌐 WebSocket Headers - CONFIGURACIÓN COMPLETA
    proxy_set_header Connection $connection_upgrade;
    # 🏷️ Headers de identificación
    proxy_set_header Host $host;
    proxy_set_header X-Real-IP $remote_addr;
    proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    proxy_set_header X-Forwarded-Proto $scheme;
    # ⏱️ Timeouts extendidos para WebSockets
    proxy_read_timeout 86400;
    proxy_send_timeout 86400;
    proxy_connect_timeout 86400;
# 🎯 LOCACIÓN ESPECÍFICA PARA WEBHOOKS Y API (Opcional pero recomendado)
location /rest/ {
    proxy_pass http://localhost:5678/rest/;
:wrench: Variable para manejo de conexiones WebSocket (Agregar en http block)
Si no tienes acceso al http block principal, usa esta alternativa:
map $http_upgrade $connection_upgrade {
default upgrade;
‘’ close;
I would appreciate any help; I’ve been at this for several days now.
Hey @Danger_Gonzalez Welcome to the n8n community!
Your docker instance configurations seems fine, and its strange that your local docker instance is behaving like this, since it has been days, have you tried using the npm’s n8n version? To check if that works or not? you can download that using ‘npm install -g n8n’ and for running it locally just type ‘n8n’ and done, and see for any errors or n8n not behaving as it should. Let me know if you need any help with that
Cheers!
