Help with double loop Looping
I have a set of google sheet rows to update. One field is a , delimited list of image urls.
each google sheet row needs to loop through this field, upload images, and then the whole row gets uploaded to wordpress (the list of images as image gallery). Its all working amazing EXCEPT if I send multiple rows through. then when I aggragate the images uploaded, the rest of the rows dont run. The aggragate seems to collapse it all.
the loop in the screen shot is the loop that uploads each image to wordpress. the aggrate takes the 5 images and put them into a list, but also seems to clear out the larger rows/items going through the routine…
no error, only 1 of the multiples rows make it through.
  "nodes": [
      "parameters": {
        "pollTimes": {
          "item": [
              "mode": "everyMinute"
        "documentId": {
          "__rl": true,
          "value": "1bsT9tRtXO0LXt4aV-dCIVR971wRLxDd2mMeUk5e1t5c",
          "mode": "list",
          "cachedResultName": "Registered Booths - Start Automation",
          "cachedResultUrl": "https://docs.google.com/spreadsheets/d/1bsT9tRtXO0LXt4aV-dCIVR971wRLxDd2mMeUk5e1t5c/edit?usp=drivesdk"
        "sheetName": {
          "__rl": true,
          "value": 1698920634,
          "mode": "list",
          "cachedResultName": "Approved - to Post",
          "cachedResultUrl": "https://docs.google.com/spreadsheets/d/1bsT9tRtXO0LXt4aV-dCIVR971wRLxDd2mMeUk5e1t5c/edit#gid=1698920634"
        "options": {}
      "type": "n8n-nodes-base.googleSheetsTrigger",
      "typeVersion": 1,
      "position": [
        -160,
        0
      "id": "c241d03d-4e48-4923-ae1a-0d7cc3d34eae",
      "name": "Google Sheets Trigger",
      "credentials": {
        "googleSheetsTriggerOAuth2Api": {
          "id": "EhLkcCT1hclQNL1G",
          "name": "GoodHumans"
      "parameters": {
        "operation": "update",
        "documentId": {
          "__rl": true,
          "mode": "list",
        "sheetName": {
          "__rl": true,
          "mode": "list",
          "cachedResultName": "pre-application-tattoo",
        "columns": {
          "mappingMode": "defineBelow",
          "value": {
            "Legal Name": "{{ $('Loop Over Items').last().json.Artist_Name }}",
            "Cover_Image": "{{ $json.image_url }}",
            "ADDED-WP": "YES"
          "matchingColumns": [
            "Legal Name"
          "schema": [
              "id": "Legal Name",
              "displayName": "Legal Name",
              "required": false,
              "defaultMatch": false,
              "display": true,
              "type": "string",
              "canBeUsedToMatch": true,
              "removed": false
              "id": "Links (Website and Social Media) 1",
              "displayName": "Links (Website and Social Media) 1",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Links (Website and Social Media) 2",
              "displayName": "Links (Website and Social Media) 2",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Email Address",
              "displayName": "Email Address",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Confirm Email Address",
              "displayName": "Confirm Email Address",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Shop Name",
              "displayName": "Shop Name",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Shop Links (Website and Social Media) 1",
              "displayName": "Shop Links (Website and Social Media) 1",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Shop Links (Website and Social Media) 2",
              "displayName": "Shop Links (Website and Social Media) 2",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Shop Email Address",
              "displayName": "Shop Email Address",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Confirm Shop Email Address",
              "displayName": "Confirm Shop Email Address",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Are You CPR, First Aid, BBP Certified?",
              "displayName": "Are You CPR, First Aid, BBP Certified?",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Do You Have a Current DPOR License?",
              "displayName": "Do You Have a Current DPOR License?",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Will You Get a Temporary DPOR for Permanent License",
              "displayName": "Will You Get a Temporary DPOR for Permanent License",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Have You Attended the VB Festival Before?",
              "displayName": "Have You Attended the VB Festival Before?",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "What Years",
              "displayName": "What Years",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Attach 5 of your best tattoos",
              "displayName": "Attach 5 of your best tattoos",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Upload your Headshot",
              "displayName": "Upload your Headshot",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Your Bio",
              "displayName": "Your Bio",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Created By (User Id)",
              "displayName": "Created By (User Id)",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Entry Id",
              "displayName": "Entry Id",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Entry Date",
              "displayName": "Entry Date",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "Cover_Image",
              "displayName": "Cover_Image",
              "required": false,
              "display": true,
              "type": "string",
              "id": "gallery",
              "displayName": "gallery",
              "required": false,
              "display": true,
              "type": "string",
              "removed": true
              "id": "ADDED-WP",
              "displayName": "ADDED-WP",
              "required": false,
              "display": true,
              "type": "string",
              "id": "row_number",
              "displayName": "row_number",
              "required": false,
              "display": true,
              "type": "string",
              "readOnly": true,
              "removed": true
          "attemptToConvertTypes": false,
          "convertFieldsToString": false
        "options": {}
      "type": "n8n-nodes-base.googleSheets",
      "typeVersion": 4.5,
      "position": [
        2760,
        220
      "id": "7e64fda3-7335-4c20-856d-51930224ea64",
      "name": "Google Sheets",
      "credentials": {
        "googleSheetsOAuth2Api": {
          "id": "3aySnlhMZZIzXbE7",
          "name": "goodhumans"
      "parameters": {
        "method": "POST",
        "url": "https://wordpress-220562-5408258.cloudwaysapps.com/wp-json/wp/v2/media",
        "authentication": "predefinedCredentialType",
        "nodeCredentialType": "wordpressApi",
        "sendHeaders": true,
        "headerParameters": {
          "parameters": [
              "name": "Content-Disposition",
              "value": "attachment; filename=image.jpg"
        "sendBody": true,
        "contentType": "binaryData",
        "inputDataFieldName": "data",
        "options": {}
      "typeVersion": 4.2,
      "position": [
        820,
        20
      "id": "5b716689-6718-4833-97cd-96185ca685fc",
      "name": "upload headshot",
      "credentials": {
        "wordpressApi": {
          "id": "EfwAwyZuXU7m5ETL",
          "name": "Wordpress account"
      "parameters": {
        "url": "={{ $json.image_url }}",
        "options": {}
      "typeVersion": 4.2,
      "position": [
        700,
        220
      "id": "d0963ee3-cb85-447f-9b31-3a74e598c387",
      "name": "download headshot"
      "parameters": {
        "method": "POST",
        "url": "=https://wordpress-220562-5408258.cloudwaysapps.com/wp-json/wp/v2/artist/{{ $json.id }}",
        "sendBody": true,
        "specifyBody": "json",
        "jsonBody": "={\n  \"acf\": { \n\t\t\t\"shop_name\" : \"{{ $('Artist Info').item.json.shop_name }}\",\n\"artist_gallery_link\" : \"{{ $('Artist Info').item.json.social_media }}\",\n\"shop_website\" : \"{{ $('Artist Info').item.json.shop_website }}\",\n\"artist_photos\" : [{{ $('Aggregate').item.json.id }}]\n \n\n\t}\n} \n",
        "options": {}
      "typeVersion": 4.2,
      "position": [
        2500,
        0
      "id": "a02e17e5-0719-49d6-9062-890a5a14e277",
      "name": "Update Artist Info",
      "credentials": {
        "wordpressApi": {
      "parameters": {
        "options": {
          "reset": false
      "type": "n8n-nodes-base.splitInBatches",
      "typeVersion": 3,
      "position": [
        1620,
        20
      "id": "dd52a6c8-7550-49a6-bd79-76b204cd0b36",
      "name": "Loop Over Items1",
      "retryOnFail": true
      "parameters": {
        "assignments": {
          "assignments": [
              "id": "b904ba40-943f-4743-a264-f5fc587d5597",
              "name": "tattoos",
              "value": "={{ $('Artist Info').last().json.tattoos }}",
              "type": "string"
        "options": {}
      "type": "n8n-nodes-base.set",
      "typeVersion": 3.4,
      "position": [
        1060,
        20
      "id": "6e09723c-62f3-4d54-93d8-e4e6c4f2e3b8",
      "name": "Get 5 Tattoos"
      "parameters": {
        "url": "={{ $json.tattoo }}",
        "options": {}
      "typeVersion": 4.2,
      "position": [
        2020,
        120
      "id": "d82e3cb5-6fc3-4838-99e1-8bbd476ffee4",
      "name": "download tattoo",
      "retryOnFail": true
      "parameters": {
        "method": "POST",
          "parameters": [
        "sendBody": true,
        "options": {}
      "typeVersion": 4.2,
      "position": [
        2180,
        120
      "id": "8a34cb18-fc83-49fe-83c2-d05ee2cbba5a",
      "name": "upload tattoo",
      "alwaysOutputData": true,
      "retryOnFail": true,
      "credentials": {
        "wordpressApi": {
      "onError": "continueErrorOutput"
      "parameters": {
        "options": {
          "reset": false
      "typeVersion": 3,
      "position": [
        300,
        0
      "id": "dc35ba74-bb1c-43bb-b945-6284492cb0e4",
      "name": "Loop Over Items"
      "parameters": {
        "assignments": {
          "assignments": [
              "id": "cd60f988-579f-4898-830a-2e0f92699803",
              "name": "Artist_Name",
              "value": "={{ $json['Artist Name'] }}",
              "type": "string"
              "id": "a9a5822c-df27-425a-8be2-41b52acb72f7",
              "name": "Studio_Name",
              "value": "={{ $json['Shop Name'] }}",
              "type": "string"
              "id": "208c7460-4ba2-4747-87d1-fbddfab2f2ae",
              "name": "social_media",
              "value": "={{ $json['Links (Website and Social Media) 1'] }}",
              "type": "string"
              "id": "e8f0cfc6-783d-4c69-b3ca-277727ff5f73",
              "name": "shop_name",
              "type": "string"
              "id": "493965bb-caf8-451c-a253-84441d9c8738",
              "name": "shop_website",
              "value": "={{ $json['Shop Links (Website and Social Media) 1'] }}",
              "type": "string"
              "id": "b1483989-5e84-4680-b7aa-a5f9925029fe",
              "name": "tattoos",
              "value": "={{ $json['Attach 5 of your best tattoos'] }}",
              "type": "string"
              "id": "928ce4da-5ff6-4b00-b52e-cb77c2709f1a",
              "name": "bio",
              "value": "={{ $json['Short Bio'] }}",
              "type": "string"
              "id": "fe4f7286-24a9-40b1-b266-914539edac56",
              "name": "headshot",
              "value": "={{ $json[\"Upload your Headshot\"] }}",
              "type": "string"
        "options": {}
      "typeVersion": 3.4,
      "position": [
        540,
        20
      "id": "15d2378d-cf7e-4476-ace0-3a18865b94e2",
      "name": "Artist Info"
      "parameters": {
        "method": "POST",
        "url": "https://api.placid.app/api/rest/xlzzlg6blsndu",
          "parameters": [
              "name": "Authorization",
              "value": "Bearer placid-jazfrn7lgnyftyfc-osar1h626xespfye"
        "sendBody": true,
        "specifyBody": "=json",
        "bodyParameters": {
          "parameters": [
        "jsonBody": "={\n  \"template_uuid\": \"8surzq5vkfpv7\",\n  \"layers\": {\n      \"feature\": {\n          \"image\": \"{{ $json.headshot }}\"\n      },\n     \"artist\": {\n          \"text\": \"{{ $json.Artist_Name }}\"\n      }\n  },\n  \"create_now\": true\n}",
        "options": {
          "proxy": "",
          "timeout": 300000
      "typeVersion": 4.2,
      "position": [
        540,
        220
      "id": "b62ba65d-6a01-428c-a9b7-f0e01863c16b",
      "name": "artist-headshot"
      "parameters": {
        "documentId": {
          "__rl": true,
          "mode": "list",
        "sheetName": {
          "__rl": true,
          "mode": "list",
        "filtersUI": {
          "values": [
              "lookupColumn": "ADDED-WP"
        "options": {}
      "typeVersion": 4.5,
      "position": [
        20,
        0
      "id": "1fe85551-b276-468a-a81d-6f19cbf01407",
      "name": "New Artists",
      "credentials": {
      "parameters": {
        "instructions": "the tattoos contains a list of images with escape characters. please remove the escape characters. output needs to be seperate array's for each tattoo image for a loop node",
        "codeGeneratedForPrompt": "the tattoos contains a list of images with escape characters. please remove the escape characters. output needs to be seperate array's for each tattoo image for a loop node",
        "jsCode": "const items = $input.all();\nconst updatedItems = items.map((item) => {\n  const tattoos = JSON.parse(item?.json?.tattoos);\n  const cleanedTattoos = tattoos.map((tattoo) => tattoo.replace(/\\\\/g, \"\"));\n  return cleanedTattoos;\n});\nreturn updatedItems.flat().map((tattoo) => ({ tattoo }));\n"
      "type": "n8n-nodes-base.aiTransform",
      "typeVersion": 1,
      "position": [
        1240,
        20
      "id": "255ec339-b6ab-44ee-89b2-646b792b24fd",
      "name": "AI Transform2"
      "parameters": {
        "fieldsToAggregate": {
          "fieldToAggregate": [
              "fieldToAggregate": "id"
        "options": {}
      "type": "n8n-nodes-base.aggregate",
      "typeVersion": 1,
      "position": [
        1920,
        -40
      "id": "de77f4f8-35b1-4999-9dea-76519ade86d2",
      "name": "Aggregate"
      "parameters": {
        "method": "POST",
        "url": "https://wordpress-220562-5408258.cloudwaysapps.com/wp-json/wp/v2/artist/",
        "sendBody": true,
        "bodyParameters": {
          "parameters": [
              "name": "title",
              "value": "={{ $('Artist Info').last().json.Artist_Name }}"
              "name": "featured_media",
              "value": "={{ $('upload headshot').last().json.id }}"
              "name": "content",
              "value": "={{ $('Artist Info').last().json.bio }}"
        "options": {}
      "typeVersion": 4.2,
      "position": [
        2240,
        -100
      "id": "ac70c8de-38ee-48d9-a930-21d7f68240f7",
      "name": "Create Draft Blog1",
      "credentials": {
        "wordpressApi": {
  "connections": {
    "Google Sheets Trigger": {
      "main": [
            "node": "New Artists",
            "type": "main",
            "index": 0
    "Google Sheets": {
      "main": [
            "node": "Loop Over Items",
            "type": "main",
            "index": 0
    "upload headshot": {
      "main": [
            "node": "Get 5 Tattoos",
            "type": "main",
            "index": 0
    "download headshot": {
      "main": [
            "node": "upload headshot",
            "type": "main",
            "index": 0
    "Update Artist Info": {
      "main": [
            "node": "Google Sheets",
            "type": "main",
            "index": 0
    "Loop Over Items1": {
      "main": [
            "node": "Aggregate",
            "type": "main",
            "index": 0
            "node": "download tattoo",
            "type": "main",
            "index": 0
    "Get 5 Tattoos": {
      "main": [
            "node": "AI Transform2",
            "type": "main",
            "index": 0
    "download tattoo": {
      "main": [
            "node": "upload tattoo",
            "type": "main",
            "index": 0
    "upload tattoo": {
      "main": [
            "node": "Loop Over Items1",
            "type": "main",
            "index": 0
    "Loop Over Items": {
      "main": [
            "node": "Artist Info",
            "type": "main",
            "index": 0
    "Artist Info": {
      "main": [
            "node": "artist-headshot",
            "type": "main",
            "index": 0
    "artist-headshot": {
      "main": [
            "node": "download headshot",
            "type": "main",
            "index": 0
    "New Artists": {
      "main": [
            "type": "main",
            "index": 0
    "AI Transform2": {
      "main": [
            "type": "main",
            "index": 0
    "Aggregate": {
      "main": [
            "node": "Create Draft Blog1",
            "type": "main",
            "index": 0
    "Create Draft Blog1": {
      "main": [
            "node": "Update Artist Info",
            "type": "main",
            "index": 0
  "pinData": {},
  "meta": {
    "instanceId": "d50ae9164ab3b3fbd3a4986b8409f1d4cf3572c019e3a46f2953720743860f6a"
## Share the output returned by the last node
<!-- If you need help with data transformations, please also share your expected output. -->
- **n8n version:**
 n8n@1.86.1
- **Database (default: SQLite):**
SQLite
- **n8n EXECUTIONS_PROCESS setting (default: own, main):**
own,main
- **Running n8n via (Docker, npm, n8n cloud, desktop app):**
n8ncloud
- **Operating system:**
Mac
thanks in advance!
Hey :slight_smile:
can’t see workflow properly, could u try by sharing like this plz,
n8n attach workflow
wierd, I did! here it is thanks:
“nodes”: [
“parameters”: {
“pollTimes”: {
“item”: [
“mode”: “everyMinute”
“documentId”: {
“__rl”: true,
“value”: “1bsT9tRtXO0LXt4aV-dCIVR971wRLxDd2mMeUk5e1t5c”,
“mode”: “list”,
“cachedResultName”: “Registered Booths - Start Automation”,
“cachedResultUrl”: “Registered Booths - Start Automation - Google Sheets”
“sheetName”: {
“__rl”: true,
“value”: 1698920634,
“mode”: “list”,
“cachedResultName”: “Approved - to Post”,
“options”: {}
“type”: “n8n-nodes-base.googleSheetsTrigger”,
“typeVersion”: 1,
“position”: [
-160,
0
“id”: “c241d03d-4e48-4923-ae1a-0d7cc3d34eae”,
“name”: “Google Sheets Trigger”,
“credentials”: {
“googleSheetsTriggerOAuth2Api”: {
“id”: “EhLkcCT1hclQNL1G”,
“name”: “GoodHumans”
“parameters”: {
“operation”: “update”,
“documentId”: {
“__rl”: true,
“mode”: “list”,
“sheetName”: {
“__rl”: true,
“mode”: “list”,
“cachedResultName”: “pre-application-tattoo”,
“columns”: {
“mappingMode”: “defineBelow”,
“value”: {
“Legal Name”: “{{ $(‘Loop Over Items’).last().json.Artist_Name }}”,
“Cover_Image”: “{{ $json.image_url }}”,
“ADDED-WP”: “YES”
“matchingColumns”: [
“Legal Name”
“schema”: [
“id”: “Legal Name”,
“displayName”: “Legal Name”,
“required”: false,
“defaultMatch”: false,
“display”: true,
“type”: “string”,
“canBeUsedToMatch”: true,
“removed”: false
“id”: “Links (Website and Social Media) 1”,
“displayName”: “Links (Website and Social Media) 1”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Links (Website and Social Media) 2”,
“displayName”: “Links (Website and Social Media) 2”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Email Address”,
“displayName”: “Email Address”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Confirm Email Address”,
“displayName”: “Confirm Email Address”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Shop Name”,
“displayName”: “Shop Name”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Shop Links (Website and Social Media) 1”,
“displayName”: “Shop Links (Website and Social Media) 1”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Shop Links (Website and Social Media) 2”,
“displayName”: “Shop Links (Website and Social Media) 2”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Shop Email Address”,
“displayName”: “Shop Email Address”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Confirm Shop Email Address”,
“displayName”: “Confirm Shop Email Address”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Are You CPR, First Aid, BBP Certified?”,
“displayName”: “Are You CPR, First Aid, BBP Certified?”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Do You Have a Current DPOR License?”,
“displayName”: “Do You Have a Current DPOR License?”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Will You Get a Temporary DPOR for Permanent License”,
“displayName”: “Will You Get a Temporary DPOR for Permanent License”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Have You Attended the VB Festival Before?”,
“displayName”: “Have You Attended the VB Festival Before?”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “What Years”,
“displayName”: “What Years”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Attach 5 of your best tattoos”,
“displayName”: “Attach 5 of your best tattoos”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Upload your Headshot”,
“displayName”: “Upload your Headshot”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Your Bio”,
“displayName”: “Your Bio”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Created By (User Id)”,
“displayName”: “Created By (User Id)”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Entry Id”,
“displayName”: “Entry Id”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Entry Date”,
“displayName”: “Entry Date”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Cover_Image”,
“displayName”: “Cover_Image”,
“required”: false,
“display”: true,
“type”: “string”,
“id”: “gallery”,
“displayName”: “gallery”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “ADDED-WP”,
“displayName”: “ADDED-WP”,
“required”: false,
“display”: true,
“type”: “string”,
“id”: “row_number”,
“displayName”: “row_number”,
“required”: false,
“display”: true,
“type”: “string”,
“readOnly”: true,
“removed”: true
“attemptToConvertTypes”: false,
“convertFieldsToString”: false
“options”: {}
“type”: “n8n-nodes-base.googleSheets”,
“typeVersion”: 4.5,
“position”: [
2760,
220
“id”: “7e64fda3-7335-4c20-856d-51930224ea64”,
“name”: “Google Sheets”,
“credentials”: {
“googleSheetsOAuth2Api”: {
“id”: “3aySnlhMZZIzXbE7”,
“name”: “goodhumans”
“parameters”: {
“method”: “POST”,
“url”: “https://wordpress-220562-5408258.cloudwaysapps.com/wp-json/wp/v2/media”,
“authentication”: “predefinedCredentialType”,
“nodeCredentialType”: “wordpressApi”,
“sendHeaders”: true,
“headerParameters”: {
“parameters”: [
“name”: “Content-Disposition”,
“value”: “attachment; filename=image.jpg”
“sendBody”: true,
“contentType”: “binaryData”,
“inputDataFieldName”: “data”,
“options”: {}
“typeVersion”: 4.2,
“position”: [
820,
20
“id”: “5b716689-6718-4833-97cd-96185ca685fc”,
“name”: “upload headshot”,
“credentials”: {
“wordpressApi”: {
“id”: “EfwAwyZuXU7m5ETL”,
“name”: “Wordpress account”
“parameters”: {
“url”: “={{ $json.image_url }}”,
“options”: {}
“typeVersion”: 4.2,
“position”: [
700,
220
“id”: “d0963ee3-cb85-447f-9b31-3a74e598c387”,
“name”: “download headshot”
“parameters”: {
“method”: “POST”,
“url”: “=https://wordpress-220562-5408258.cloudwaysapps.com/wp-json/wp/v2/artist/{{ $json.id }}”,
“sendBody”: true,
“specifyBody”: “json”,
“jsonBody”: “={\n "acf": { \n\t\t\t"shop_name" : "{{ $(‘Artist Info’).item.json.shop_name }}",\n"artist_gallery_link" : "{{ $(‘Artist Info’).item.json.social_media }}",\n"shop_website" : "{{ $(‘Artist Info’).item.json.shop_website }}",\n"artist_photos" : [{{ $(‘Aggregate’).item.json.id }}]\n \n\n\t}\n} \n”,
“options”: {}
“typeVersion”: 4.2,
“position”: [
2500,
0
“id”: “a02e17e5-0719-49d6-9062-890a5a14e277”,
“name”: “Update Artist Info”,
“credentials”: {
“wordpressApi”: {
“parameters”: {
“options”: {
“reset”: false
“type”: “n8n-nodes-base.splitInBatches”,
“typeVersion”: 3,
“position”: [
1620,
20
“id”: “dd52a6c8-7550-49a6-bd79-76b204cd0b36”,
“name”: “Loop Over Items1”,
“retryOnFail”: true
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “b904ba40-943f-4743-a264-f5fc587d5597”,
“name”: “tattoos”,
“value”: “={{ $(‘Artist Info’).last().json.tattoos }}”,
“type”: “string”
“options”: {}
“type”: “n8n-nodes-base.set”,
“typeVersion”: 3.4,
“position”: [
1060,
20
“id”: “6e09723c-62f3-4d54-93d8-e4e6c4f2e3b8”,
“name”: “Get 5 Tattoos”
“parameters”: {
“url”: “={{ $json.tattoo }}”,
“options”: {}
“typeVersion”: 4.2,
“position”: [
2020,
120
“id”: “d82e3cb5-6fc3-4838-99e1-8bbd476ffee4”,
“name”: “download tattoo”,
“retryOnFail”: true
“parameters”: {
“method”: “POST”,
“parameters”: [
“sendBody”: true,
“options”: {}
“typeVersion”: 4.2,
“position”: [
2180,
120
“id”: “8a34cb18-fc83-49fe-83c2-d05ee2cbba5a”,
“name”: “upload tattoo”,
“alwaysOutputData”: true,
“retryOnFail”: true,
“credentials”: {
“wordpressApi”: {
“onError”: “continueErrorOutput”
“parameters”: {
“options”: {
“reset”: false
“typeVersion”: 3,
“position”: [
300,
0
“id”: “dc35ba74-bb1c-43bb-b945-6284492cb0e4”,
“name”: “Loop Over Items”
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “cd60f988-579f-4898-830a-2e0f92699803”,
“name”: “Artist_Name”,
“value”: “={{ $json[‘Artist Name’] }}”,
“type”: “string”
“id”: “a9a5822c-df27-425a-8be2-41b52acb72f7”,
“name”: “Studio_Name”,
“value”: “={{ $json[‘Shop Name’] }}”,
“type”: “string”
“id”: “208c7460-4ba2-4747-87d1-fbddfab2f2ae”,
“name”: “social_media”,
“value”: “={{ $json[‘Links (Website and Social Media) 1’] }}”,
“type”: “string”
“id”: “e8f0cfc6-783d-4c69-b3ca-277727ff5f73”,
“name”: “shop_name”,
“type”: “string”
“id”: “493965bb-caf8-451c-a253-84441d9c8738”,
“name”: “shop_website”,
“value”: “={{ $json[‘Shop Links (Website and Social Media) 1’] }}”,
“type”: “string”
“id”: “b1483989-5e84-4680-b7aa-a5f9925029fe”,
“name”: “tattoos”,
“value”: “={{ $json[‘Attach 5 of your best tattoos’] }}”,
“type”: “string”
“id”: “928ce4da-5ff6-4b00-b52e-cb77c2709f1a”,
“name”: “bio”,
“value”: “={{ $json[‘Short Bio’] }}”,
“type”: “string”
“id”: “fe4f7286-24a9-40b1-b266-914539edac56”,
“name”: “headshot”,
“value”: “={{ $json["Upload your Headshot"] }}”,
“type”: “string”
“options”: {}
“typeVersion”: 3.4,
“position”: [
540,
20
“id”: “15d2378d-cf7e-4476-ace0-3a18865b94e2”,
“name”: “Artist Info”
“parameters”: {
“method”: “POST”,
“url”: “https://api.placid.app/api/rest/77pzapjqjrfpp”,
“parameters”: [
“name”: “Authorization”,
“value”: “Bearer placid-u20yoqz57pwkshoz-ykwklx6a73dkjk7z”
“sendBody”: true,
“specifyBody”: “=json”,
“bodyParameters”: {
“parameters”: [
“jsonBody”: “={\n "template_uuid": "77pzapjqjrfpp",\n "layers": {\n "feature": {\n "image": "{{ $json.headshot }}"\n },\n "artist": {\n "text": "{{ $json.Artist_Name }}"\n }\n },\n "create_now": true\n}”,
“options”: {
“proxy”: “”,
“timeout”: 300000
“typeVersion”: 4.2,
“position”: [
540,
220
“id”: “b62ba65d-6a01-428c-a9b7-f0e01863c16b”,
“name”: “artist-headshot”
“parameters”: {
“instructions”: “the tattoos contains a list of images with escape characters. please remove the escape characters. output needs to be seperate array’s for each tattoo image for a loop node”,
“codeGeneratedForPrompt”: “the tattoos contains a list of images with escape characters. please remove the escape characters. output needs to be seperate array’s for each tattoo image for a loop node”,
“jsCode”: “const items = $input.all();\nconst updatedItems = items.map((item) => {\n const tattoos = JSON.parse(item?.json?.tattoos);\n const cleanedTattoos = tattoos.map((tattoo) => tattoo.replace(/\\/g, ""));\n return cleanedTattoos;\n});\nreturn updatedItems.flat().map((tattoo) => ({ tattoo }));\n”
“type”: “n8n-nodes-base.aiTransform”,
“typeVersion”: 1,
“position”: [
1240,
20
“id”: “255ec339-b6ab-44ee-89b2-646b792b24fd”,
“name”: “AI Transform2”
“parameters”: {
“fieldsToAggregate”: {
“fieldToAggregate”: [
“fieldToAggregate”: “id”
“options”: {}
“type”: “n8n-nodes-base.aggregate”,
“typeVersion”: 1,
“position”: [
1920,
-40
“id”: “de77f4f8-35b1-4999-9dea-76519ade86d2”,
“name”: “Aggregate”
“parameters”: {
“method”: “POST”,
“url”: “https://wordpress-220562-5408258.cloudwaysapps.com/wp-json/wp/v2/artist/”,
“sendBody”: true,
“bodyParameters”: {
“parameters”: [
“name”: “title”,
“value”: “={{ $(‘Artist Info’).last().json.Artist_Name }}”
“name”: “featured_media”,
“value”: “={{ $(‘upload headshot’).last().json.id }}”
“name”: “content”,
“value”: “={{ $(‘Artist Info’).last().json.bio }}”
“options”: {}
“typeVersion”: 4.2,
“position”: [
2240,
-100
“id”: “ac70c8de-38ee-48d9-a930-21d7f68240f7”,
“name”: “Create Draft Blog1”,
“credentials”: {
“wordpressApi”: {
“parameters”: {
“sendTo”: “gabe@tattoonow.com”,
“subject”: “It’s done”,
“message”: “It;'s done”,
“options”: {}
“type”: “n8n-nodes-base.gmail”,
“typeVersion”: 2.1,
“position”: [
720,
-260
“id”: “335e1bdf-f266-4dc4-9269-95c8061e903a”,
“name”: “Gmail”,
“webhookId”: “c4ab151d-0eff-413c-a5af-f2e1b833c025”,
“credentials”: {
“gmailOAuth2”: {
“id”: “mBOIURNKPG53sVKx”,
“name”: “Gmail account”
“connections”: {
“Google Sheets Trigger”: {
“main”: [
“node”: “Loop Over Items”,
“type”: “main”,
“index”: 0
“Google Sheets”: {
“main”: [
“type”: “main”,
“index”: 0
“upload headshot”: {
“main”: [
“node”: “Get 5 Tattoos”,
“type”: “main”,
“index”: 0
“download headshot”: {
“main”: [
“node”: “upload headshot”,
“type”: “main”,
“index”: 0
“Update Artist Info”: {
“main”: [
“node”: “Google Sheets”,
“type”: “main”,
“index”: 0
“Loop Over Items1”: {
“main”: [
“node”: “Aggregate”,
“type”: “main”,
“index”: 0
“node”: “download tattoo”,
“type”: “main”,
“index”: 0
“Get 5 Tattoos”: {
“main”: [
“node”: “AI Transform2”,
“type”: “main”,
“index”: 0
“download tattoo”: {
“main”: [
“node”: “upload tattoo”,
“type”: “main”,
“index”: 0
“upload tattoo”: {
“main”: [
“node”: “Loop Over Items1”,
“type”: “main”,
“index”: 0
“Loop Over Items”: {
“main”: [
“node”: “Gmail”,
“type”: “main”,
“index”: 0
“node”: “Artist Info”,
“type”: “main”,
“index”: 0
“Artist Info”: {
“main”: [
“node”: “artist-headshot”,
“type”: “main”,
“index”: 0
“artist-headshot”: {
“main”: [
“node”: “download headshot”,
“type”: “main”,
“index”: 0
“AI Transform2”: {
“main”: [
“type”: “main”,
“index”: 0
“Aggregate”: {
“main”: [
“node”: “Create Draft Blog1”,
“type”: “main”,
“index”: 0
“Create Draft Blog1”: {
“main”: [
“node”: “Update Artist Info”,
“type”: “main”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “d50ae9164ab3b3fbd3a4986b8409f1d4cf3572c019e3a46f2953720743860f6a”
ah, help! Is there a tutorial on looping through rows of a sheet, and then having a loop inside the flow for an item in the row perhaps?
