The idea is:
Add a hierarchical grouping view to the Execution History (both the global Overview page and per-workflow execution lists) that visually groups parent workflow executions with their sub-workflow executions in a collapsible tree structure, instead of listing every execution as an independent, flat row.
When a parent workflow (Workflow A) triggers sub-workflows B, C, D, E via the Execute Sub-workflow node, all of these currently appear as separate, unrelated rows in the execution history. The proposal is to:
- Group parent + child executions in a collapsible tree, with the parent row showing an expandable indicator (
/▼) and a badge like ⧉ 6 sub-executions - Show aggregate metadata on the parent row: total run time across the tree, number of children, aggregate status (all success / partial failure / failed)
- Add a toggle: “Group orchestration executions” to switch between the current flat view and the new grouped view
- Use tree-line indentation (├─ └─) to show parent → child → grandchild depth within the grouped view
- Add a filter option: “Hide sub-workflow executions” to only display top-level/root executions (similar to Temporal’s “Show Child Workflows” toggle)
(Above: Left panel shows the current flat execution list where 7+ related executions appear as independent rows. Right panel shows the proposed grouped view where the parent execution collapses its children into a tree.)
My use case:
I build orchestration-heavy automation systems where a single logical operation (e.g., “Delete a marketplace listing”) triggers a chain of 5-10+ sub-workflows:
[CORE]~[Marketplace Router]~[Delete]~[Single Item] ← Parent (orchestrator)
├─ [API]~[Marketplace]~[****]~[Delete Account] ← Sub-workflow 1
├─ [API]~[Marketplace]~[****]~[Delete Acc.] ← Sub-workflow 2
├─ [API]~[Marketplace]~[****]~[Delete Account] ← Sub-workflow 3 (has own children)
│ ├─ Sub-workflow: User Verification ← Grandchild
│ ├─ Sub-workflow: Deactivate Token ← Grandchild
│ └─ Sub-workflow: Record Deletion Audit ← Grandchild
├─ [CORE]~[Marketplace Router]~[Delete]~[Single Item] ← Sub-workflow 4
└─ [API]~[Marketplace]~[Airtable Manager]~[Delete...] ← Sub-workflow 5
Currently, all of these show up as independent rows in the execution history, making it:
- Impossible to understand at a glance what happened — I see “67 production executions” but the actual number of logical operations is far fewer; the count is inflated by sub-workflow noise
- Extremely difficult to debug failures — when one sub-workflow in a chain fails, I have to manually cross-reference execution IDs and timestamps to find which parent triggered it and which siblings ran alongside it
- Cluttered and noisy — the execution list becomes dominated by sub-workflow rows that obscure the actual top-level business operations
The “View sub-execution” link inside the Execute Workflow node (added in v1.69.0) is helpful for navigating one-at-a-time between parent ↔ child, but it doesn’t solve the core problem: the execution list itself has no concept of grouping.
(Above: Real execution history from my n8n instance, all rows are listed independently with no visual indication of which executions belong to the same orchestrated operation.)
(Above: The tooltip already mentions “Hierarchical view of orchestration-mode executions” — the concept exists but isn’t fully implemented in the execution list.)
1. The backend data already exists
Since v1.69.0, the Execute Workflow node stores parentExecution metadata containing executionId and workflowId on child executions. The relationship graph is already persisted — it just needs to be surfaced in the UI.
2. Every major workflow orchestration platform has solved this
- Temporal has a “Show Child Workflows” toggle and a Relationships tab that displays the full parent/child hierarchy as a tree. They also allow viewing child workflow timelines inline without navigating away.
- Prefect links every child flow run to its parent via
parent_task_run_idand shows a dedicated “Sub Flow Runs” tab when viewing a parent execution. - Apache Airflow uses Task Groups in the Grid View that can be expanded/collapsed, showing nested task hierarchies with duration bars.
n8n is increasingly being used for complex orchestration (multi-agent AI systems, microservice-style workflow architectures, marketplace automation), but the execution observability hasn’t kept pace.
3. Community demand
This has been requested multiple times across the community:
- “Link Sub Workflow with Parent Workflow” (2022) — noted that
parentExecutionIdexists in the codebase but isn’t fully used - “Easy access to sub workflows (drill-down)” (2024) — requested ability to view sub-workflow progress and errors without manually navigating
- “Access top-level workflow ID and execution ID in subworkflows” (2025) — requested traceability back to the root workflow
- “Any way to get complete execution cycle of workflow→sub workflows?” (2025) — confirmed the API response is “flat” with no native parent-child linking
4. It reduces noise and improves execution count accuracy
The Overview dashboard’s “Prod. executions” counter becomes misleading when most executions are sub-workflows. Grouping would let users understand their actual operation count vs. the total execution count.
How other platforms handle this:
| Platform | Feature | Description |
| Temporal | Show Child Workflows toggle | Toggle to hide/show child workflows in the execution list; Relationships tab shows full parent/child tree |
| Temporal | Inline child timeline | View child workflow timeline directly from parent’s execution detail (Compact & Timeline views) |
| Prefect | Sub Flow Runs tab | Each parent flow run has a “Sub Flow Runs” tab listing all child flows with their status; parent_task_run_id links relationships |
| Airflow | Task Groups in Grid View | Collapsible task groups in the grid view showing nested hierarchy with duration and status |
n8n internal references:
- v1.69.0 parentExecution metadata: The
Execute Workflow Triggernode already storesmetadata.parentExecution.executionIdandmetadata.parentExecution.workflowId— this is the exact data needed to build the hierarchy - Execution Public API: The
/executionsendpoint returns flat results; adding aparentExecutionIdfilter orinclude=childrenparameter would complement the UI change
Suggested implementation approach:
- Query enhancement: When fetching executions, optionally JOIN on
parentExecutionIdto build a tree structure - UI grouping: Render parent rows with expand/collapse controls; indent child rows with tree lines
- Toggle: Add “Group by orchestration” toggle (default off for backward compatibility)
- Filter: Add “Hide sub-workflow executions” filter to show only root-level executions
- Badge: Show
⧉ N sub-executionsbadge and aggregate status on parent rows
I would be willing to help test, provide feedback, and contribute to the UI specification. The core backend data (parentExecution metadata) is already there, this is primarily a frontend/UI enhancement to the execution list component.
