How do i connect with slack?
Im trying to connect to slack to run some workflow test im following a tutorial but not getting any luck. when i try add credentials it doesnt show this config option when trying to connect with slack 0auth API
any ideas how i can see this screen?
here’s how to see the slack oauth config screen:
  1. in n8n, go to “credentials” > “new” > search for “slack api”
  2. select “slack oauth2 api” (not regular slack api)
  3. if you don’t see it:
  • update n8n to latest version
  • check you have admin/owner permissions
  • try different browser or incognito mode
need the oauth url? use:
https://your-n8n-domain.com/rest/oauth2-credential/callback
still stuck?
Let me know! creativeimpact348 (@) g mail. com
