- n8n version:
- Database (default: SQLite):
- Operating system:
@Everett_Sobinsky , I see two issues with the setup of Summarize node:
- Field name is expect but you use an array
- Splitting by the same field to which aggregation is applied
What is your input data and what output you expect to get?
Here’s an example of the usage for better understanding how Summarize works.
Outcome
What my Summarization does is, it counts (Aggregation: Count) the number of fields count segregated by the property domain. That is, in the JSON input the items containing domain “abc” and the property cost is only 1 as the other 2 items in this domain have no property cost.
Similarly, the domain “def” has 2 items that contain the property cost.
Does it align with your expectation?
